Swapped out the Kaze fenders for the stock ones. Was getting over the top vents and poor alignment.
Had to drill a extra bolt hole in each fender to pull the bar up tight.
Before extra bolt
After extra bolt
Installed the dual pump washer bottle I had lying in the garage for over 2 years.
Also raised the front 1cm so should now sit at 11cm.
Before extra bolt
After extra bolt
- spetz
What's the purpose of the dual pump?
More water pressure, or for a rear washer?
Should hook up an inter cooler spray EVO style
Yup, that was the plan from 2 years ago. Have had all the bits just never got around to it.silverGPX wrote:Should hook up an inter cooler spray EVO style
Exactly the same plan. One of these days I'll install mine.Vectose wrote:Yup, that was the plan from 2 years ago. Have had all the bits just never got around to it.silverGPX wrote:Should hook up an inter cooler spray EVO style
- Kustom
I've got that but for my radsilverGPX wrote:Should hook up an inter cooler spray EVO style
:lol: And I've still only got 2mm clearance with my brakes.Kustom wrote:Watch them slip on spacers mate, geez. [emoji14] :lol:Vectose wrote:
- payaya
Gearbox went for the third time left me again with no drive at a set of lights. Stuff paying 3k again rebuild it myself, $700 all up and running sweet. Splines in torque converter gone, opened up gearbox, clutches worn down to the steel so got a re-seal kit, steels clutches and rebuilt uprated torque converter!
You are a patient man.payaya wrote:Stuff paying 3k again rebuild it myself, $700 all up and running sweet. Splines in torque converter gone, opened up gearbox, clutches worn down to the steel so got a re-seal kit, steels clutches and rebuilt uprated torque converter!
- payaya
- Lawso
- Penis Fingers
Looked at them both
Shrugged
Walked away
Shrugged
Walked away
- bjk
- Totes
Didn't even look at mine
- getonit
Hosed the bird sh*t off the windscreen. Called it a c**t and went inside and drank beer.
Yeah, looked at mine, procrastinated about fixing the fuel blockage, then had a Viagra & got tin the hot tub with the missus.
I've had 6 wanks this morning btw.
- getonit
New stepper & TPS in snoor3!
- getonit
I put seats in the c**t, and that is more than it deserves.
- IMG_20230625_153248_3.jpg (372.47 KiB) Viewed 3521 times
- IMG_20230625_165934_2.jpg (337.03 KiB) Viewed 3521 times
In the quest for a more balanced audio experience, I'm now considering alternatives. The Pioneer Slimlines have caught my attention for their low-profile design, and I'm intrigued by their potential to deliver that extra punch without sacrificing too much space. Additionally, I'm contemplating the idea of going for a conventional 10" Kicker sub, which might offer the right balance of size and performance.
The goal is to find something compact enough to snugly fit between my back seats and the rear strut bar while still enhancing the bass beyond what my current 6x9s deliver. If anyone has experiences or recommendations in this realm, I'd love to hear them. The quest for the perfect blend of sound and space efficiency continues!
