GR and GPX parts (interchangeable?)
- mindxcycle
Hey Guys,
I'm wondering if i can find a place or just information on what can be
interchanged between the GR and GPX (1995).
Mostly looking at suspension stuff and if we can swap parts over etc.
The GR has an awesome suspension setup but it has a gearbox problem at the moment while
the GPX at the moment has mostly stock everything.
Any information/direction and advice is appreciated
Thanks guys
Thanks guys
- Dras
Re: GR and GPX parts (interchangeable?)
The only difference between the 2 models is the engine so you can interchange everything else.
Not true, rear swaybar links are differentDras wrote:The only difference between the 2 models is the engine so you can interchange everything else.
And brakes
- BorepYano
and the sticker, one usually says "GPX", the other probably will be "GR".
- bjk
- Totes
BorepYano wrote:and the sticker, one usually says "GPX", the other probably will be "GR".
And the sway bars are smaller too! (iirc)Vectose wrote:Not true, rear swaybar links are differentDras wrote:The only difference between the 2 models is the engine so you can interchange everything else.
- Dras
Well if we are being pedantic then the wheels are also different to accommodate the larger brakes in the GPX.
- bjk
- Totes
Yeah but the GR 15s are probably the rarest FTO part out there.Dras wrote:Well if we are being pedantic then the wheels are also different to accommodate the larger brakes in the GPX.
- payaya
Vin plates different.
- mindxcycle
Thanks guys
A set came up for sale a couple of months ago here in the UK. AUD$85 / £50 collected. It's all about supply and demand. 15's aren't in high demand.bjk wrote:Yeah but the GR 15s are probably the rarest FTO part out there.Dras wrote:Well if we are being pedantic then the wheels are also different to accommodate the larger brakes in the GPX.
