Big brake kit
MOR31
Re: Big brake kit
Post by MOR31 »
the PFL bolts right up as it uses the same 130mm bolt space, FL uses 160mm so wont boult without a plate
Re: Big brake kit
OK, u've lost me, what is PFL & FL? :lol:
MOR31
Re: Big brake kit
Post by MOR31 »
Pre Face Lift, Face Lift. just when they change a few things from year to year
Re: Big brake kit
OK, so the hubs you have these bolted to are FTO pre face lift?
I wasn't aware that the hubs were different? I know the GR brakes and GPX/GPvR brakes are different calipers and rotors, so maybe they have different hubs also, but GPX is also pre face lift?
Edit: Of course they're not, otherwise you wouldn't be able to upgrade GPX brakes on a GR :facepalm2:
Anyway, so the VR4 calipers bolt straight up to the FTO pre face lift hubs (130mm bolt spacing). And the VR4 rotors (294mm) then bolt straight on, correct offset etc. Have I got it right yet :?:
MOR31
Re: Big brake kit
Post by MOR31 »
its the galants that are PFL and FL, fto didnt chage, just maybe fabric trim.
yes the vr4 calipers bolt up no problems with the 294mm rotors. could prob find you some as i have a few mates with vr4 galants
Re: Big brake kit
lol thanks but I've just spent $400 on a new set of Brembo rotors which should last me a while :)
More interested for future reference. If the VR4 pre facelift model calipers and rotors are a direct bolt on it's another upgrade option for the FTO, a step up from GPX brakes but not quite to the EVO Brembo level Ben has just installed, but much easier. It also possibly opens up a whole range of possible aftermarket bolt ons also. So very useful info, thank you :thumleft:
Re: Big brake kit
That is good to know!
Yeah, the hubs I used off the Evo had the 160mm bolt spacing.
Re: Big brake kit
I'm also now told the rear hubs off a 2wd 8th gen Galant will bolt to the rear, so I can use the Brembo rears. I'll get to that :lol:
Most of you saw this on FB yesterday, but finished up the repaint & new Brembo decals on the fronts 8)
Re: Big brake kit
That looks so sexy :twisted: .
Re: Big brake kit
Here's the DIY on how to fit rear Brembos.
I'm not sure why use the Galant back plate when you could use the entire assembly off the Evo, but anyways..
http://www.coltuk.org/phpbb3/viewtopic.php?f=20&t=14083
Re: Big brake kit
More FYI. One of the hubs I've got has worn splines on the inside, giving me a 'clang' when I release the clutch in a hurry, so I started researching the hubs & what replacements are available.
As per usual, I have to replace the whole f@cking wheel bearing assembly... of which Chris Meek challenged me to find for any less than $300 bucks.
First stop was Camskill @ 155 quid + postage:
http://www.camskill.co.uk/m8b0s2323p111 ... n_5_6_CP9A
Then Amayama @ $243 Aus
http://www.amayama.com/search/?q=MR334386
Then Ebay @ $124 + $65 postage...
http://www.ebay.com.au/itm/300686075114 ... 750wt_1163
Then I though, f**k this, I'll cross reference it with the US model Dodge Challengers, RVRs & Eclipses etc...
Low & behold, it's used on just about every Eclipse that was ever released.
Which led me to these guys in the US...
$55 bucks + postage 8)
http://stores.channeladvisor.com/Auto-P ... ing%204Cyl
Re: Big brake kit
fkn nice job there.
Re: Big brake kit
Hey Ben, let us know what the shipping will be on a pair of these - if its reasonable i will probably grab a pair for Maverick at that price... Might even get a cheaper post with an extra 2 in there? :twisted:
Re: Big brake kit
Nice shopping ben. 8)
Re: Big brake kit
Don't forget to put the part numbers and pics in the parts area :D .
Re: Big brake kit
thats stupidly cheap, all of the other prices seem 'reasonable'
Re: Big brake kit
SchumieFan wrote:thats stupidly cheap, all of the other prices seem 'reasonable'
I do agree.
Reminds me of my Walbro fuel pump bargain.
Low and behold it gave out after a month of barely any use.
But can't hurt to try...
Even with postage it's still a lot cheaper than the others.
Re: Big brake kit
Freight out of the US was f**king expensive as usual ($110) but even then, its still works out at $110 per side. Cheaper than eBay by 80 bucks.
Re: Big brake kit
Just ordered some lightweight rotors 8)
Lightest ones on the market, the 2 piece Baer EradiSpeed-Plus rotors.
To give some comparative weight numbers per rotor:
Stock rotors - 9.7kg
DBA 5000 - 8.4kg
Girodisc 2pc - 8.25kg
Project Mu SCR-Pro - 8.16kg
Baer Eradispeed - 7kg
So that's almost 3kgs of rotating mass removed from each side...
$480 for the pair out of the US. Just waiting on what will no doubt be a hideous freight cost :lol: Thinking it'll be around the $250 mark.
BI65ND
Re: Big brake kit
Post by BI65ND »
MOR31 wrote:might be a bit late but i just did a fto 5 stud swap onto my lancer coupe, used fto rear setup and used fto front hub and knuckle but then used a 8th gen vr4 galant 294mm rotor twin pot setup, need the pre face lift as it uses the same 130mm bolt space as the facelife uses 160mm space same as evo4 up.
As if you'd do this swap :-P
I have also recently done the same swap on my mirage with FTO hubs. The 294mm setup from the legnum/galant VR4 (6A13TT) 'Pre-facelifts' are a direct bolt on to the FTO hub. No mods required. Also interestingly, the inner caliper is the same as the standard FTO one and uses the same brake pads. Which worked out great for me because I retained my relatively new EBC Reds :D
