Haltech Tuning and mods
fto96
Post by fto96 »
hey guys just got a few qeustions im installing a haltech inteceptor on my gpx my engine mods are , I/H/E i also want to get a bigger throttle body i heard that magna 3.5 ones are bigger and fit straight on all i have to do is port the manifold to match it right? any other engine mods i can do for it without cracking the motor apart :P
anyone else running a haltech on there n/a fto? and anyone got base maps? YES I SEARCHED LOL
Re: Haltech Tuning and mods
Aza and I have Haltech Premium piggybacks installed.
    fto96
    Post by fto96 »
    how do you like it? this is my first haltech on my personal car but i work with standalones at work but never tried out a piggyback one
    Where did you grab yours from and how much did you pay fto96?
    Love mine. Getting 133KW atw with significantly better fuel economy that I was getting pre-install. Once of the best value mods ivehad done.
      shadowarrior wrote:Where did you grab yours from and how much did you pay fto96?
      Just come to terms with it, Tightwad :lol: You need to spend at least a grand.
      fto96
      Post by fto96 »
      Yes its not cheap but you get what you pay for... i got it through my job, anyways bavk on subject 133kw sounds good too me :D but can anyone comfirm that a magna tb is actually larger and will fit? And where i can find base maps
      Yes Magna 65mm throttle body will fit. Although be warned you will most likely run a bit lean on idle. At higher RPM you will be OK though.
      Solution: keep it redlined!
      Pretty sure ive got the base maps. PM me an email address.
        Lol its gem off facebook
        :D :lol:
        fto96
        Post by fto96 »
        silverGPX wrote:Lol its gem off facebook
        lol i made an account on fto australia right?? and cheers fella's and by running lean topend im geussing injectors run out?
        fto96
        Post by fto96 »
        Daniel2019 wrote:Yes Magna 65mm throttle body will fit. Although be warned you will most likely run a bit lean on idle. At higher RPM you will be OK though.
        sorry bud didnt read that correctly i thought you said run lean at redline aha... cant i just add more fuel at idle with the haltech?( never tuned a piggy back before i know i can do it with a stand alone)
        vipfto
        Post by vipfto »
        Sure can any reasonable piggyback can add/remove fuel at any rev range
