6a13 flywheel bolts
Spike28278
6a13 flywheel bolts
Post by Spike28278 »
So ive got my engine on a stand, and im trying to remove the flywheel bolts but im having trouble, anybody habe any experience?
Are the reverse threadded?
Re: 6a13 flywheel bolts
Rattle gun.
Or have someone hold the harmonic balancer bolt with a breaker bar while you undo then with another breaker bar
Spike28278
Ill try the rattle gun, i bought one recently its just a pain to take it off the engine stand
I tried using 2 breaker bars but it ended up just undoung the harmonic balancer bolt every time :/ i even tried using the rattle gun on it to tighten it
dazjb
Post by dazjb »
I locked the flywheel using a piece of ally plate and a couple of bolts. Worked a treat ...
Oxy..
Spike28278
Cheers for all the advice ill have a crack at it this weekend
I might need to hire a oxy torch if all else fails
