amp up the 6.5" or 6.9" ?
dr390
Post by dr390 »
i recently installed my subs and a brand new head unit this week, my next job is to replace my 6.5's and buy another amp either for the 6.5's or 6.9's?
when i do connect an amp what else do i need? another set or leads?
Tell me when i stop
Uploaded with ImageShack.us
Re: amp up the 6.5" or 6.9" ?
6x9!!!!
dr390
Post by dr390 »
6.9" would be the go lols
what do i need apart from the amp its self?
Tell me when i stop
Didn't you just amp your sub? Same things.
dr390
Post by dr390 »
lol, i've only rewired it three times on my own system
im not that familiar just yet :roll:
Tell me when i stop
bduffman
Post by bduffman »
Depends on your speakers
Y not just buy a 4 channal and amp them both ?
U will need ground wire pos wire remote wire rca cables fuse fuse holder think that's bout it off top of my head
I prob should put my sub and amps in my car there just getting stuffed out in the shed
dr390
Post by dr390 »
bduffman wrote:Depends on your speakers
why not just buy a 4 channal and amp them both ?
you will need ground wire pos wire remote wire rca cables fuse fuse holder think that's bout it off top of my head
cause i've had a amp and sub from my first car so all i really need is another amp
and my first amp was only two channels lols
so yeah pretty noob still with my audio but gettin better
Tell me when i stop
bduffman
Post by bduffman »
In my old corolla I had 1 sub 6 speakers 3 amps 1 mono and 2 2chs fronts had 2 speakers per door
a mono is an amp... so does that mean u had 4 amps?
bduffman
Post by bduffman »
No 3 amps
1 mono
2 two channal
My mono is underpowered for the sub though its only 600rms and the subs 2000rms
dr390
Post by dr390 »
why whats the difference between a mono and a normal two channel amp?
Tell me when i stop
koolio1234
Post by koolio1234 »
bduffman wrote:No 3 amps
1 mono
2 two channal
Are you sure it was 2000 watt RMS?
That sounds more like the peak power.
Who knows its buffman. Could mean anything
Dont amp the 6.9's if they are in the back, amp the fronts.
bduffman
Post by bduffman »
nar its a hcca 12inch orion can look up the stats if you want its 2000rms and 4000peak its way to big for the fto though
amps alpine pdx1 ,600
silverGPX wrote:Dont amp the 6.9's if they are in the back, amp the fronts.
No you should use a 4 chanel amp and be amping ALL the speakers
