System Setting
nikhan
System Setting
Post by nikhan »
Ok finally got my Head Unit :)
It has 3 RCA preouts so I'm just wondering what set up should I use. I already have a amp and a subby as well. Need some advice.
I was planning to hook up my sub to the HU, my rear speakers to the HU and my front speakers to the Amp.
Or is it better to hook up my front to the HU, and my sub and rear to the Amp
Or are there some other setup that is better.
Re: System Setting
how many channels does amp have?
Will need to run sub off amp then depending what the amp can handle run speakers if possible
nikhan
Re: System Setting
Post by nikhan »
Oh its a 4 channel amp :)
spency
Re: System Setting
Post by spency »
Sub and fronts off the amp (if you have the wiring)
Rears off head unit
^good balance
Re: System Setting
Bridg the sub off 3 & 4 and run fronts off 1 & 2. Then get a good set of 6x9's for the back running of the HU.
Better still get a mono block for the sub and run the speakers off the other one.
nikhan
Re: System Setting
Post by nikhan »
Sweet...will run the fronts and sub off the amp and the rear to the HU.
Yeah I got meself a pair of kicker 6x9s :)
Thanks guys
