Car Audio (Jaycar Subs)
RomaFTO1989
Post by RomaFTO1989 »
Time for my very first posts and ICE build-log.
2 x 12" Jaycar Carbon fibre subs.
Dual Driver Custom Box
1500Watt Precision Response AMP
The build bits 18mm MDF. + tools + SUBS
2 x 12" Jaycar Subwoofers (been gathering dust for nearly 12months)
The sketched box design [Designed with Pro-Desktop then volume checked with WinISD]
The cut out components...
The Subs loaded in to check tolerance..
Terminals Screwed in. Wires Connected
Double Baffle Board screwed in,
...and routed
Bring on the Red Leather
Subs loaded and polished and amp plate glued down.
AMP. Wired and screwed down a free gromit for the power was found below the wiper motor VERY CONVENIENT !!!
DOOR TRIMS!!!!
....Neons have since been installed and such. Photos coming.................................
Re: Car Audio (Jaycar Subs)
Impressive work,
How do you rate the subs?
RomaFTO1989
HardCore!! yeah i was impressed they are 400watts @ 2ohms "apparently". I can post box dimensions if you need them.
They put out like mad and bass is clean and crisp. and goddam PUNCHY. Dual coils wired in series and yet still slams!!!
mattman
Post by mattman »
nice job mate nothing better then working on your own car
FTO ftw
Work looks good mate
How much are they each to buy?
Looks very nice!
the leather looks good too!
RomaFTO1989
I'm LOVING the response from my first public build feels good
....SUBS $250 each they have been discontinued from Jaycar but still available around the place.
they were 4ohms not 2ohms as i stated ^^ hence the good crisp sound at high wattage
Specifications:
- Power Handling: 300WRMS
- Impedance: 4ohms (dual voice coil)
- Voice Coil Resistance (Re): 1.7ohm
- Mechanical Q Factor (Qms): 3.238
- Electrical Q Factor (Qes): 0.446
- Total Q Factor (Qts): 0.392
- Equivalent Volume (Vas): 79.454Ltr
- Sensitivity: 88.152dB/Wm
- BL: 9.992 TM
- for: 28.77Hz
- Sd: 514.72 sqCM
LEATHER
Yeah the leather is good very cheap 30$ for 1500x1400mm
BUT
It was a right "mike hunt" to get to stick to the flex of the door WAY to thick.
will be doing the rear side panels int he same red vinyl as well.
And red carbon fibre wrap for the dash parts.
BOX
Dimensions and graphs.
It's not something I would have in my car, but great work it looks sweet :twisted: .
RomaFTO1989
Boot space is 50% but is well worth it. As I'm a musician have to have to have it loud or louder. :D
Nice build.
Good to hear someone else rates the Response well also.
RomaFTO1989
Have you used the response subs in your FTO?
umm, I have a history with the response gear so to speak.
But the fto has all response audio bar the headunit.
Rumor is that the Response gear is getting completely discontinued (no more car audio), so if people like the gear then they had better stock up.
RomaFTO1989
FAAAAARRRRKKKK!!!! its such a good cost price car audio solution. I talked to my local retailer and asked to talk directly to the supplier to ask for sponsorship...
local computer shop - jaycar - jaycar corporate - dead end. I couldn't find the direct contact for response anywhere.. :(
And you won't.
And you won't get sponsorship either :lol:
Response isn't one company, Response is splashed across a few items Jaycar sells.
The subs come from one manufacturer, the amps from another and so on.
It used to be all one manufacturer some time ago, but no longer.
Same with all Jaycar stuff, the 'brand' names are merely Jaycar registered and can be applied to any and everything that's imported through them.
RomaFTO1989
The unfortunate truth :x
Taiwo
Post by Taiwo »
nice job man. that is exactly what i wanted to do to my car interior. i wanted to wrap everythin in red and black. if you were in brisbane i could so pay you to do it for me because i seem to destroy everythin i touch
"Is that a supra???".
"What's a Mitsubishi FTO?"
Taiwo I don't think it would be that hard I was going to look at doing it to my FTO when I get it running I live in Brisbane too I might attempt this.
Taiwo
Post by Taiwo »
sweet. let me know when you get this going. i might come around and see how you do it
FTO-BOY
Post by FTO-BOY »
Hey just curious... Where are you from? I think I've seen you around campbelltown area
