Amp mounting.
c0n13oX
Amp mounting.
Post by c0n13oX »
Where have people mounted their amps? Will one fit under the passenger seat?
Re: Amp mounting.
Honestly ...
Get a bit of MDF. Cut it and fit it behind the passenger seat. When you take the seats out, there is a piece of black plastic which you can use as a template...
Put the MDF there, and mount in the boot. Amps under seats can pick up a lot of heat. And there is no circulation. Trust me when I say the way above is easier...
c0n13oX
Re: Amp mounting.
Post by c0n13oX »
Do you mean passenger seat or rear seats?
Re: Amp mounting.
You can put one under the front passenger seat although it may need get enough air and overheat. I have mine bolted to the back of my sub box [attachment=-1]uploadfromtaptalk1398210674630.jpg[/attachment] like so
Re: Amp mounting.
c0n13oX wrote:Do you mean passenger seat or rear seats?
Rear seats..
Remove rear seats - get template - cut MDF
Put black plastic back - put MDF in - put seats back in
You can feed the wires through the MDF to the amp and power up without seeing a cord... Or just feed all wires through the bottom of the boot floor up to the amp and speakers...
Much better option than under a seat. Plus the FTO sits pretty low, so you will have even more reduced air flow. I am lucky in the Swift, as I could fit a DSP an under seat sub under the seats... With still plenty of height ...
c0n13oX
Re: Amp mounting.
Post by c0n13oX »
The black plastic would be the piece seperating the back seat and boot yeah? I was wondering of that could be done. Will definately do that, cheers mate
Re: Amp mounting.
c0n13oX wrote:The black plastic would be the piece seperating the back seat and boot yeah? I was wondering of that could be done. Will definately do that, cheers mate
That is the one champ ...
c0n13oX
Re: Amp mounting.
Post by c0n13oX »
Sweet
Re: Amp mounting.
c0n13oX wrote:Sweet
If I still had mine, I would snap some photo's ... I may have a build thread somewhere though ... Will have a look ...
Re: Тема
Poropunenko wrote:Должен признать, вебмастер зачетно накропал.
I agree.
Re: Amp mounting.
Don't mount amps to the back of boxes
