Wheels.
c0n13oX
Wheels.
Post by c0n13oX »
Hey all,
Looking at getting some 17x7.5 wheels on the car, what sort of offset should i be looking at to get a more flush sorta look?
Cheers
Re: Wheels.
Where's BJK when we need him :lol:
Re: Wheels.
kiz wrote:Where's BJK when we need him :lol:
You called?
This will help willtheyfit.com :lol:
What wheels exactly are you looking at? To get them flush with that sort of width is going to require a fairly low offset. e.g. I'm running 9 inch wide rims with a +22 offset, and they end up, with about -2 degrees camber in the rear, like this:
On the front, they do poke a little bit, and I'm running 235/45 tyres, so they will clip the guards (which are all rolled) around hard corners/bumps.
Basically, unless you've got coilovers and can adjust the height/camber to avoid that sort of thing, look for a width/offset that will mean the wheel/tyre can still travel up vertically uninhibited by the guards, haha. I reckon another 10mm or so back into the guards and I'd be fairly sure I'd clear.
c0n13oX
Re: Wheels.
Post by c0n13oX »
I'm just more interested in what will fit, as I'm pretty sure the VIC laws only allow 1 inch wider and bigger.
Re: Wheels.
Yeah I'd comply with the laws in Vic I've heard they aren't too lenient down there
c0n13oX
Re: Wheels.
Post by c0n13oX »
Yeah, they aren't.... lucky us :P
c0n13oX
Re: Wheels.
Post by c0n13oX »
So I should be looking for something with a smaller offset to poke out more?
Re: Wheels.
c0n13oX wrote:So I should be looking for something with a smaller offset to poke out more?
That's the idea. e.g. The lower the number, the further away from the centre of the car the edge of the wheel will be.
ed: bearing in mind, most offsets for that width don't go much lower than 30-35. Depends what you can find. So yeah, if you want it actually quite flush, you might have to go a bit wider, or use spacers. Neither of which are probably ideal for you if you want to avoid the legal stuff.
c0n13oX
Re: Wheels.
Post by c0n13oX »
Ahk, thanks for the help:)
Re: Wheels.
If you felt like going a half inch wider than 7.5, could go something like these. A guy who imports mostly Mazda parts, but has few just general wheels as well. $931.
Partway down this post: http://www.astinagt.com/forums/showpost ... count=1536
Re: Wheels.
How about just getting a sensible size set of tims and tyres lol
c0n13oX
Re: Wheels.
Post by c0n13oX »
I'll take a look at that man, thanks.
Re: Wheels.
Daniel2019 wrote:sensible size set of tims
Well, we have one sensible sized Tim down here in Adelaide already, how many makes a set? :lol:
But yeah, probably don't need to go 9 inch like I did. Though I do like the bit of stretch with the 235's. 8)
But both Sahin and Vectose are running 17x8 at about that offset, though IIRC Vectose will be going 235/40 for his next set of tyres.
Re: Wheels.
Mine are +38 too lol and no scrub at all anywhere, and mine is lower than matts car just
