Shane-O, you should go buy some jackstands now :)
Re: Shane-O, you should go buy some jackstands now :)
Wow
Seen it happen before...
Happens quite a bit... :?
I remember a guy in Melbourne, had an old Manaro.. Was his pride and joy, had it from brand new in the factory... He was retired, and working on it one day in the garage, wife hadn't seen him for a while, and went out to check on him... Crushed by the car...
Safety is very important, and no matter how many times you have worked on a car, or how knowledgeable you are, things can always go wrong. So make sure you abide by simple safety measures...
And that was my jack ... :lol:
She be right
Yep I always use stands. And on my hoist at work, I check arms before car leaves the ground, again when it's just off the ground, check it shaking front or rear bumper/tyre then it can go up further.
Safety first!
I also find that drinking ones body weight in beer prior to doing anything mechanical helps safety as well.
I just use me head as a wheel chock
Stands and wheel chocks here...
I can't stand using the scissor jacks...
Bennoz wrote:I also find that drinking ones body weight in beer prior to doing anything mechanical helps safety as well.
Oh yeah, and safety thongs.
