Droplink UK Group Buy *Very Cheap* (Camskill - 20% Discount)
mr-charisma
Post by mr-charisma »
Hey guys, there's no end date on the offer, just a minimum amount of people to be interested, we only need two more to get this happening.. I'll post a follow up thread & see if we get more interest..
FtoSam
Post by FtoSam »
Righto...
Had some big bills come in that i wasnt expecting.
So i've pulled out of everything except the Leads..
Sorry for the hassle
DROPLINKS (FRONT & REAR)
1.) Mr-Charisma - GPX - Not Lowered
2.) Topao - GPX - Not Lowered
3.) Benm7 - GPX - Not Lowered
4.) JoeJoe - GPX - Not Lowered
5.) pimped - GPX - Not Lowered
6.) Onnzo - GR - Not Lowered
7.) Richy - GPX - Not Lowered
8.)
9.)
10.)
11.) Grue - GR (fronts only)
TEIN PILLOWMOUNTS
1.) Grue
2.) Mr-Charisma (Maybe)
3.)
Magnecor Leads - $103 (GPX/GPvR) $119 (GR)
1.) FTOSam - GR
2.) Grue - GR
3.) Mr-Charisma - GPX
4.) Richy - GPX
Braided Steel Brake Lines - $157 AUD
1.) Mr-Charisma
Grue
Post by Grue »
Ok, to help try to make up the numbers...
8.) Grue - GR - Not Lowered
9.)
10.)
TEIN PILLOWMOUNTS
1.) Grue
3.)
1.) FTOSam - GR
2.) Mr-Charisma - GPX
3.) Richy - GPX
4.) Grue - GR
1.) Mr-Charisma
my fronts are noisy as!!
One think I have no idea about is diagnosing if they are faulty!
How do you know if your bushes or drop link is faulty???
onnzo
Post by onnzo »
Get under there and have a look. Mine are at a wierd angle because all the rubber is worn!
With cars our age and the links being consumable I would guess that they are worn on most fto's.
Mike
im getting like a springy compressing squeak type noise from my front right everytime I go over a speed hump.
what does that mean?
Grue
Post by Grue »
Likely to be Droplinks and/or Bushes. Ben's Suspension sticky is where I learnt a lot from.
http://www.ftoaustralia.com/modules.php ... pic&t=5944
mr-charisma wrote:Most Auto dealers here either stock Superpro Poly bushes or can order them in, they're manufactured here so I think its actually cheaper. Just cost me $205 for all bushes.. you can get all but one set for about $110. Just get a price from Supercheap & go to Autobarn / Burson Autoparts or the manufacturer ( www.fulcrumsuspensions.com.au ) & ask for a better deal
I'll have to get back to you on the Part numbers for the Links ..
Hey might give the bushes a go first and see what happens. Whats the Part number numbers??
Thanks
whats the mitsubishi front bushes part numbers?
benm7
Post by benm7 »
Sorry guys, gonna have to pull out of the droplinks group buy, i need to order them asap.
Maybe camskill can give us a 15% discount for 8 ppl instead :)
Grue
Post by Grue »
Worth a try asking them - what with the 4 people wanting leads as well...
As for the Tein Pillow mounts, looks like PerfectRun do them for about AU$200 delivered.
9.)
10.)
TEIN PILLOWMOUNTS
1.) Mr-Charisma (Maybe)
2.)
3.)
1.) FTOSam - GR
3.) Richy - GPX
4.) Grue - GR
1.) Mr-Charisma
Im out mine are fine.
benm7
Post by benm7 »
Sorry guys, have to pull out. Just ordered a set through Camskill, had to get them, EMERGENCY!
But cheers anyway for organising, will definately keep an eye out for more group buys.
3.) JoeJoe - GPX - Not Lowered
4.) pimped - GPX - Not Lowered
5.) Onnzo - GR - Not Lowered
6.) Richy - GPX - Not Lowered
7.) Grue - GR - Not Lowered
8.)
9.)
10.)
TEIN PILLOWMOUNTS
2.)
3.)
1.) FTOSam - GR
3.) Richy - GPX
4.) Grue - GR
1.) Mr-Charisma
Grue
Post by Grue »
Really not going anywhere fast are we chaps. Thought we'd have got 10 easy!
8.)
9.)
10.)
TEIN PILLOWMOUNTS
2.)
3.)
1.) FTOSam - GR
3.) Richy - GPX
4.)
1.) Mr-Charisma
SG
Post by SG »
Might get some new droplinks...
Just thinking if lowering the car makes the rear anti roll bar less effective when you dont have the special shortened drop links. might be where my understeer is comming from...? :?
8.) SG - GPX - Lowered
9.)
10.)
TEIN PILLOWMOUNTS
2.)
3.)
1.) FTOSam - GR
3.) Richy - GPX
4.)
1.) Mr-Charisma
SG
Post by SG »
As it turns out the wrx STI 04-06 rear drop/end links are exactly the same as the fto's... http://www.whiteline.com.au/docs/instru ... KLC047.pdf
also did some searching and there seems to be quite a few different "performance" ones made up for them (besides the whiteline ones) by US companies. performance as in, the more solid the drop link the more supposedly responsive the sway bar/cars handling will be. but i think they're just more sturdier/longer lasting. cant really imagine a drop link flexing with the suspension... they're only small...
also found out that the adjustable ones are for setting up the drop link and sway bar so that when the car is sitting normal, the sway bar end (per side) is horizontal and the drop link can then be dead vertical... which is supposed to optimise the effectiveness of the sway bar so that its not preloaded or underneath the working range or whatever. which would change per the height that your suspension is set if its not stock, im guessing.
sounds like adjustable is the way to go if you really wanna optimise your suspension/ARB for the track etc.
going to go get some whiteline ones i think instead of camskills
the max rear ARB size for the fto is 22mm anyway...the reaallly sturdy droplinks would only be usefull for the sti when using 27mm+ ARBs during motorsport and need to last a while.
they look pretty though:
http://www.hptmotorsports.com/agency_po ... legacy.php
http://www.hptmotorsports.com/perrin_re ... acy_gt.php
whiteline has an alloy one aswell...
http://www.rallysportdirect.com/static/ ... -3075.html
SG
Post by SG »
8.)
9.)
10.)
TEIN PILLOWMOUNTS
2.)
3.)
1.) FTOSam - GR
3.) Richy - GPX
4.)
1.) Mr-Charisma
FtoSam
Post by FtoSam »
Sorry mate, im gonna have to pull outta this one as well.
RPW are matching the price for me and its just easier to organise for me as theyre doing my engine...
8.)
9.)
10.)
TEIN PILLOWMOUNTS
2.)
3.)
1.) Richy - GPX
3.)
4.)
1.) Mr-Charisma
onnzo
Post by onnzo »
FtoSam wrote:Sorry mate, im gonna have to pull outta this one as well.
1.) Mr-Charisma
If this is the case, maybe we can get them off RPW instead?
mr-charisma
Ok, it looks like this GB is going nowhere fast...
I'm going with the RPW GB for Magnecor leads & braided brake cables, so if this GB does end up going ahead it will only be for droplinks..
I'll contact Camskill & see if they'll go ahead with it with 7? people..
