EOI - C's Short Shifter Group Buy
Re: EOI - C's Short Shifter Group Buy
mr-charisma wrote:
1.) Mr-Charisma
2.)vipfto (if price is right)
3.)zuihoujueding (if price is right)
4.)steve
5.}mh999(if price is right)
6.) nvr2low( if price is right)
8.) rock_it (if I have the cash when we do it)
Lets hope we get up to 10....
KJ_bob
Post by KJ_bob »
are these shorter then the rpw ones?
eddiii
Post by eddiii »
one question, does anyone have a instrustion to install these? if yes im probably up for one, and since i change my gearbox, it shouldnt affect the actualy gear stick right? thanks
Gholdwayne
Post by Gholdwayne »
[whoops]
- Eddiii, it does come with japanese instructions, got a bit of tips from ben(thanks ben), and although i cant read jap(yet?) i looked at the drawings and matched it to real life as best as i could. it wasnt too tough a job but not easy either, at least for the first time having a go at it.
be very very careful with the centre console, i cracked mine a little bit!
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
zuihoujueding
Post by zuihoujueding »
eddiii wrote:one question, does anyone have a instrustion to install these? if yes im probably up for one, and since i change my gearbox, it shouldnt affect the actualy gear stick right? thanks
y would you need this? thought u selling your ride?
Gholdwayne
he wants a bit more scratching of the itches during his numbered fto days
97 GPX Icelle Blue
FTO[For The Orgasm]
Gholdwayne wrote:[whoops]
thats why you get a japanese missus like me :lol:
but they are fairly easy to instal if it goes ahead i'll do a DIY when i do mine ;)
mr-charisma
Post by mr-charisma »
KJ_bob wrote:are these shorter then the rpw ones?
from everything i've heard, these are better than the RPW ones .. and the company that makes them specialises in short shifter kits for all different makes of cars..
hope that answers your question, BTW RPW only modifies your old shifter and you need to send your old one back, so this GB is cheaper & you get to keep your old shifter as well (as far as that matters)
Gholdwayne
wow i should have done a diy and be famous
97 GPX Icelle Blue
FTO[For The Orgasm]
bduffman
Post by bduffman »
1.) Mr-Charisma
4.)steve
9.) bduffman ( if i have the cash )
how much will this be diff from the stock shifter i read some where it will be easyer to go from 2nd to 3rd directly with out having to return to centre ,will this be a easyer shift to use
zuihoujueding
i reckon u will need a little more arm strength, given that the length of shifter is shortened.
I really hope it can shift as short as S2000, or maybe close. S2000 shifting is like half the travel of FTO! How quick is that!
mr-charisma
1.) Mr-Charisma
4.)steve
7.) rock_it (if I have the cash when we do it)
8.) bduffman ( if i have the cash )
We're actually only up to 8 so far, we missed a number there.. 2 more for the cheaper price.
Yes, it will be easier to go from 2nd to 3rd, it would be more like a diagonal movement than a zig zag (up/across/up) movement as far as I have heard - someone with one fitted may confirm..
Gholdwayne
shifting is tighter on these, which feels great, oh , and on the stock shifter, i just push the shifter from 2nd to 3rd up in one motion with my palm but in a way that i dont mistakenly hit that awkward bit in between 1st & 3rd, but yeah it is easier from 2nd to 3rd, but not significantly easier than the stock shifter imo, but just enough that you know it is...
97 GPX Icelle Blue
FTO[For The Orgasm]
Guys, you've got to understand, the mechanics of how the shifter goes from gear to gear does not change. The assembly & linkages the shifter operates with are the same, you are only swapping out the stick.
The difference with this shifter is that they've altered the pivot point of the stick. Ie, the rotation point (the ball if you will) is higher (with the use of a spacer plate,) the lower connection to the linkage is longer, and the length of the top of the stick is shorter. So effectively, the stick dimesions are the same. It loks the same, it just is able to change gears by physically being moved less distance than the factory shifter. Ie, if you had to move the stick a total distance of 2 inches to get into 1st, it will now be 1 inch etc.
bduffman
Post by bduffman »
ok so would it make it harder to change like tighter or smoother gear changes gess if dont like how it changes i can always resell it moving the pivet means shorter but wouldnt that make it harder ( like a seasaw is even but if you moved the plank a metre one way the shorter side would be hard to move then the longer ) dont mind me im just confusing my self
It still shifts the same as the stock one just shorter.
Gholdwayne
all there is to it is what ben said, its all about altering the geometry of the shifter, physically, its the same length, but shift stroke wise, its shorter, try it out, what ben said, with a pen or a stick, and you'll understand it
97 GPX Icelle Blue
FTO[For The Orgasm]
mr-charisma wrote:
1.) Mr-Charisma
4.)steve
Bump
Anymore interest in this?
mr-charisma
how long does everyone need to go ahead with this GB?
Say we set an order date of 4th June?
June sounds good to me..
Locked
