stepper motors,02 sensors & more @ Cyberspace Auto Parts
Ok I have found an Ebay shop that has it all :D
All GENUINE Mitsubishi parts :!:
Also at great prices and fast delivery too.
http://stores.ebay.com.au/Cyberspace-Auto-Parts
I just got an 02 sensor for $115 delivered and a stepper motor for $101 delivered :twisted: , Mitsubishi Aust wanted aprox $290 for a stepper motor 8O
So have a look and if they dont have it on the site give them a email as they have more in stock ready to go.
New link for the stepper motors http://www.cyberspaceautoparts.com.au/c ... Motor.html
Tippin
Post by Tippin »
nice find aza 8)
DaveO
Post by DaveO »
what was the part number for the steeper that will work on the FTO. I couldn't find any that matched CAPS.
this should be the one :-
http://cgi.ebay.com.au/MITSUBISHI-2L-2- ... tsupported
the thing I just seen though is that the O.E. number is E9T1592 but the number on the one on my car is E9T15296 :?
The HJ Galant is ment to be a strait change over with ours so it should be ok.
so a Question for Ben is there a diferent stepper for the GR and the GPX ?
edit: just had a look at another site and the number on the above listing is the right one (E9T15292)
Nah, they're all the same mate ;)
I thought for some reason that they were different even though it made no sense at the time
DaveO
Post by DaveO »
thats great.
So do i have to reset the ECU after changing the stepper?
Dave :)
I8A4RE wrote:I thought for some reason that they were different even though it made no sense at the time
There are 2 different types, but they are both the same fit. The older model was the grey housing with the brown plastic backing, it was the one notorious for failing. It was superceded by a full black plastic one that was much more reliable.
DaveO wrote:thats great.
You don't have to, but I like to do it. Sorta resets everything else too - then take it for a good flogging to relearn all its settings. May take a half a day or so for the idle to relearn what its meant to do.
Bennoz wrote:Nah, they're all the same mate ;)
thats great news I started to think that I got the wrong one :lol:
I got my new bits the other day the 02 sensor is in and will be putting the stepper in over the weekend.
this seller is fast with postage all items packed well and sent over night delivery.
bduffman
Re: stepper motors,02 sensors & more @ Cyberspace Auto Parts
Post by bduffman »
I bought a stepper motor off him last week received it the next day fit perfect cars perfect now
louiszhu
Post by louiszhu »
does the galant hj 2.0l stepper motor will fit FTO 95 gr??!
3clipz
Post by 3clipz »
louiszhu wrote:does the galant hj 2.0l stepper motor will fit FTO 95 gr??!
I have the same model as you. I bought part number MD614368 from their site. Works a treat 8)
pete_gpx
Post by pete_gpx »
http://cgi.ebay.com.au/MITSUBISHI-LANCE ... 4834801190
Any idea if these TPS will suit our cars?
escucalin
Post by escucalin »
aza013 wrote:Ok I have found an Ebay shop that has it all :D
is no good mate
the FTO lambda sensor has different specs than the one you bought
the engine ecu responds at a different interval than the sensor you bought ; in conclusion you will run eternally rich
(the voltage output of the mitsi spec sensor is way bigger than the regular ones.. consult workshop manual for these)
escucalin
Post by escucalin »
pete_gpx wrote:http://cgi.ebay.com.au/MITSUBISHI-LANCE ... 4834801190
highly unlikely
look at the appearance is shorter.. the connector is different.. no way mate!
i advise u to buy a couple sh.. the tps's go broken rarely since they are a simple variable resistor!
you will find all the instructions of how to test and fit one on the car in the workshop manual!
i got my 2 tps's with 10 euro each!
to test it fast u need a multimeter pin 1-4 -> 3,5->5Kohm
and 1-3 must rise smooth while rotated
and 1-2 must open the circuit when rotated 4-5 degrees
is no good mate
Well that's funny as I have been running it for some months now and have had no problems at all with it :?
eddiii
Post by eddiii »
hey all, just wondering, i brought the stepper motor, but on the package, it says "for 4 cylinder", is it the right one?
rynofto
Post by rynofto »
can someone verify once and for all that a stepper motor for a hj galant interchangable with the FTO. there are all these ebay links but no one has said that its the one that they bought. its mostly 'it should be this one'.
eddiii
Post by eddiii »
i brought this one, but on the box theres a sticker says "for 4cylinder" -_-
Kuran
Post by Kuran »
bump..i'm keen to find out the answer too.
