Wakefield - Mon 30th July
FTO's in Motor Sport.
* Event Results
* General Discussions
Yeah they're a lot harder than the KYBs. When I bought them I had them re-sprung thou. Brought the spring rates down as far as the valving on the shocks would allow (4.5kg front & 3.2kg rear, as opposed to stock being about 9kg & 7kg)
Now with the damper setting on its lowest they aren't too bad on the street. Still a little stiff, but bearable. Although Im on 18's but I did manage to squeeze a 45 profile tyre in with some fiddling.
Spewin' I couldn't test them on the track. Was gonna wind up the damper & give them a good work out. Fortunately I got a call from the suspension guys today & it looks like I've just blown the top seal & they dont need a full $200 a corner rebuild :)
Jono
Post by Jono »
How much did it cost to get springs for your coilovers.
did you also get helper's?
Jono
SG
Post by SG »
do you still have your old springs bennoz?
They are not actual HA coilovers, they are the direct replacement NA style Teins. Still has all the height & damper adjustment but much more suited to predominantly street use. Didnt need helpers.
Sorry SG, old springs have gone to dstocks.
But... after that, they're back :D And they are now back on the car as of this afternoon.
Stay tuned for a new Wakefield date.
We actually ought look to do an Oran Park day aswell... cause it closing down soon! :(
