Dyno results and modifications
FTO's in Motor Sport.
* Event Results
* General Discussions
Benedict_XIII
Post by Benedict_XIII »
I was wondering if anyone that had done a dyno and would like to list there results and what mods were on the car at the time this would be good to give people like me if certain mods are worth it or not and see what the fto can do what its potential is
Eltnot
Post by Eltnot »
Here's the Dyno printout from my GPX.
It's stock standard so should be a good guideline for the increase in performance given by modifications.
koolio1234
Post by koolio1234 »
My 1995 GPX (mivec) pulled 111.9 kw at the front wheels.
These are the mods done to it:
-uas air filter kit with heat shields (not quite a cai)
-high flow cat / sports exhaust with STOCK extractors
And thats it, got it dynoed with tyres at 42psi using caltex vortex98 fuel.
RallyMad
Post by RallyMad »
Just a note for people in general.
Don't be bummed if your car doesn't pull similar power numbers to others. There is so many external factors that effect dyno's that it is pretty pointless to compare different cars in different parts of the courntry. let alone the same car 6 months on. Some people are even still a little prejudeced to dyno numbers when a standard run is taken then another run after a modification is fitted. Even a few degrees of air temp difference can effect thes outputs. Especially when we are comparing with 10kw's of each other due to the limited power of our cars.
Benedict_XIII
i want 130kw + sounds reasonable i will find a way
Benedict_XIII wrote:i want 130kw + sounds reasonable i will find a way
it can be done :twisted:
CAI, exhaust, hailtech intersepter port polish and port match and you are there :twisted:
nathan
Post by nathan »
well, this is actually surprising, i was really bummed when i got my dyno reading, i got 125 hp atw, mines jus a manual GR, got pod filter, extractors high flow cat and exhaust with a dual box at the back, is this good???
if you mean 125kw not hp then yip its great
Grue
Post by Grue »
yeah, I would be a little bummed to if I got 125hp :D
