Trackday at Wakefield soon
FTO's in Motor Sport.
* Event Results
* General Discussions
zuihoujueding
Re: Trackday at Wakefield soon
Post by zuihoujueding »
thats sournds easy enough, but thats physically even harder!
the balancing act of handling two pedals(clutch and brake) of totally different pressures is a work of a pro... ;)
It won't take long for you to get it working :D .
You would get that down before you work out break and gas :lol: .
I watched a doco a while back and the race drivers' advice was "you should either be on the brakes or flat to the floor accelerating, no inbetween, not even for a second"
100% right but in turns different story.
Shane will be the best one to answer this any way :D .
:D
The answer is not that simple. Technically yes you should be brake or accel only, and learn how to trail brake into a corner (google it lol).
But with some cars if you are skilled enough you can increase corner speed by controlling car balance modulating both pedals through the corner. This is pretty advanced though.
Also I would generally not recommend using left foot for brake / right foot for accelerator, especially do not do this on the road. Firstly I'm pretty sure it is illegal (and for very good reason), secondly if you are ever in an emergency brake situation, subconsciously you will plant both feet to the floor, hitting both the accelerator and the brake. Very dangerous and hence why it is illegal to drive this way on the road, even with an auto. I have known people who have nearly killed themselves doing this!
The generally recommended and most widely used method is heel toe. Only very limited drivers carry on use of left foot / right foot from their karting days (Greg Murphy is a case in point).
As for what gear to be in, you really don't want to be dropping your revs below around 4K in the FTO at the track.
Sorry haven't had time to look at the vids 8O I'm sure you had fun though :thumleft:
zuihoujueding
finally a pro has spoken!
But i suggest you to watch the vid thou...and give me somemore pointers! :lol:
zuihoujueding wrote:finally a pro has spoken!
Nope, not me, but constantly improving :thumleft:
I'd suggest have a look at my videos and do a comparison ;)
AJ
Post by AJ »
I'm far from a pro to, but watching your vid, I'd say that turn 8 needs the most work, the line was all wrong and the car in front always pulled way ahead from you here. You need to take it from the outside, not the inside. A mistake I made at Wakefeild until I followed Aza around and took the wider angle.
