Aftermarket Replacement Parts
Re: Aftermarket Replacement Parts
KYB Shocks:
Front L: 334154
Front R: 334155
Rears: 341140
Lovell Lowered Springs:
Fronts: CFL-45
Rears: HRL-49
hj27910
Post by hj27910 »
In response to an earlier post regarding the rotors, here are the RDA numbers:
Front Disc Rotors: RDA421
Rear Disc Rotors: RDA7621
I work in spare parts and I've looked both in RDA catalogues and asked them personally as well, so this should be quite accurate. I'm happy to provide further part number if anybody has any queries!
According to DBA rep:
Rotor Size for GPX/GPvR (2.0L Mivecs stock wheel): Front Vented Rotors (276mm x 24mm) & Rear Solid Rotors (260mm x 10mm)
Part Numbers:
Front: HD Cross Drilled - DBA4425XS
Rear: HD Cross Drilled - DBA4547XS
Lower front and rear engine mounts can be had from http://www.centraldriveshaft.com.au for about $130 delivered
    dstocks wrote:Lower front and rear engine mounts can be had from http://www.centraldriveshaft.com.au for about $130 delivered
    $55 and $90 from REPCO.
    Nason lifters RHT7400 from Repco for non mivecs. $9 plus GST each which is way cheaper than anywhere else!
    FTO valve cover bolt seals from permaseal are KJ212/2. Exactly the same as the Mitsubishi ones but at a 10th of the price.
    payaya wrote:Nason lifters RHT7400 from Repco for non mivecs. $9 plus GST each which is way cheaper than anywhere else!
    Do they have Mivec lifters at all?
    shadowarrior wrote:According to DBA rep:
    Part Numbers:
    All GR rotors are the same as a 1994 HJ Galant V6 5 stud. Everyone has a listing for it as it was an aussie delivered car.
    No clue. I probably would have figured it out if I had a mivec!
    Mivec rockers can be had at Mitsubishi direct for $65.00 and most have stock.
    Mivec spark plug seals are the same as that on a Magna/Pajero 6G72/6G74. $10.00 each.
    Rob Furniss
    Post by Rob Furniss »
    payaya wrote:Mivec rockers can be had at Mitsubishi direct for $65.00 and most have stock.
    I need a couple, is that from Mitsi too?
    Yep direct from Mitsubishi. You can get the spark plug seals from ACL as they are the same in the magnas.
    Tube seals on the GR and GPX are different.
    Rear lower control arm spherical bearings or most think its a bush can be had at Mitsubishi direct for $20 each inner and $30 each outer.
    Jase726
    Post by Jase726 »
    Has anyone got a part number for GR rear wheel bearings?
    Jase726 wrote:Has anyone got a part number for GR rear wheel bearings?
    http://www.ebay.com.au/itm/MITSUBISHI-F ... 53eddcbe9a
    Thats if you don't have ABS
    Jase726
    Post by Jase726 »
    Thanks Sahin.
    Radiator cap: Tridon CB16110
    Thermostat: Tridon TT281-180
    Thermostat seal: TTG34
    Bennoz wrote:Radiator cap: Tridon CB16110
    Is that from any auto parts shop like repco or? need all of them lol
    Anyone know the part number for clutches that fit the FTO?
