Aftermarket Replacement Parts
OK, Figure that this topic should have been created as a sticky ages ago. I keep getting asked for belt part numbers and things like that. Feel free to correct them if they are wrong.
Code: Select all
What                          Brand                    Suits    Where            ~Price
Mivec timing belt (GPX)       Gates T987 (232 teeth)   GPX,GPvR Most Auto Stores ~$100
Non-Mivec timing belt (GR)    Gates T954 (226 teeth)   GR       Most Auto Stores ~$100
CV Boots                      HJ Galant ?              All      Most Auto Stores ~$20 each
Steering Rack Boots           HJ Galant                All
Timing Belt Idler Pulley      Koyo PU307034ARR1DW      GPX?
Timing Belt Tensioner Pulley  Koyo PU106218FRRID       GPX?
Power Steering/Aircon Belt    6PK1080                  All?
Alternator Belt               4PK940                   All?
Iridium Spark Plugs           NGK BKR7EKC-N-11         All?
Oil Filter                    Ryco Z411                All?
Front disks                   HJ Galant 2.0L V6        GR
Front pads                    HJ Galant 2.0L V6        GR
Front disc pads               Intima SR6300 (MD-6039M) GPX
Rear disc pads                TRW DB1278               All?
Front struts                  Same as S40 Volvo
Air Filter                    K&N: 33-2072             All
Air Filter                    RYCO: A1318              All
Air Filter                    Bosch: S 3968            All
Front Rotors (Stock)          DBA425/RDA425            GPX,GPvR
Front Rotors (Slotted)        DBA425S/RDA425S          GPX,GPvR
Front Rotors (Slot-drill)     DBA425X/RDA425X          GPX,GPvR
Strut Tops                    Same as CE Lancer        All      Pedders ~$70 each
Lower Engine Mounts (Rear)    EVO 1-3                  All      http://www.meek.com.au/index.php?act=viewProd&productId=256
Lower Engine Mounts (Front)   EVO 1-3                  All      http://www.meek.com.au/index.php?act=viewProd&productId=250
Headlight bulbs:
Low Beam: HB4 51W
Low Beam (HID): D2S (D2C also compatible)
High Beam: HB3 60W
Front foglights (Series 1): H3 55W
Front foglights (Series 2): H3 55W
Front indicators: S-25mm 21W
Side indicators: T-10mm 5W
If editing this post, ive found that copying the
Code: Select all
 section into notepad does a fairly good job of retaining spacing.
cheers
    Re: Aftermarket Replacement Parts
    Z411 - Ryco Oil Filter
    Z441 - Ryco Fuel Filter
    Front disk GR - Same as HJ Galant 2.0L V6
    Front pads GR - Same as HJ Galant 2.0L V6
    Thats it on top of my head.
    Nice work, I had been thinking about doing something like this for awhile but was too lazy.
    Added to original post payaya (thanks)
    :lol: Actually, thats precisely why I did it. Too lazy to keep answering the same question. Can never remember the numbers, so always have to search. Just got sick of it in the end.
      I have a whole of gasket numbers but they are on the other pc. I'll see if I get some time this weekend to extract them.
      factory air box air filters
      K&N: 33-2072
      RYCO: A1318
      Bosch: S 3968
      Front Rotors for GPX/ GPvR
      Normal: DBA425
      Slotted: DBA425S(L)/(R)
      Slot-drill:DBA425X
      or RDA brand, simply replace DBA
      Thanks,
      Updated original post
        Front disc pads, (GPX), Intima SR6300 (MD-6039M)
        Rear disc pads, (all?), TRW DB1278
        zaskar98
        Post by zaskar98 »
        Fuel filter Z441
        The link to the correct tappets that we need.
        http://www.meek.com.au/index.php?act=vi ... ductId=169
        Thermostat and gasket anyone?
        super cheap, cheaper auto spares HJ galant thermostat and then use this for the gasket.
        pearl_blu_fto
        Post by pearl_blu_fto »
        I know the transmission filter for the Auto models are P/N : MD 752072
        What is the A/M Part Number/s? Anyone know already off hand?
        Or what have you swapped with and works fine :)
        Cheers Damo.
        Z411 Ryco / Coopers etc etc
        Same as the engine oil filter ;)
        pearl_blu_fto
        Bennoz wrote:Z411 Ryco / Coopers etc etc
        Thanks Ben :)
        I had my doubts about it being the same or not, wanted a solid answer. Cheers :P
        okamitengu
        Post by okamitengu »
        i need a sway bar.. front.
        if i cant find one cheap interstate, or slightly more expensive here in SA, i will order one from RPW
        i want a whiteline, but any aftermarket custom will do?
        any suggestions? can i change it with evo parts? lancer? galant?
        still anoob so forgive my questions~!
        Hey Guys,
        Now the proud owner of a 98' GP version R and amongst the things already done to it i'm looking for a nice spoiler/mags/metallic paint job etc etc - the usual aftermarket stuff.
        I know of very few reputable places but is there any good places in SE QLD, near Brissie or the likes that anyone here knows that is awesome for this kind if stuff, or are they all just really the same for quality >.^
        Cheers guys,
        Just letting you guys know Permaseal do a rocket cover kit for the GR model (not sure if it is same for the GPX) cheap compared to everywhere else I have seen.
        So 2 x Rocker cover gasket and 6 x Spark plug tube seals for $75.00 at their resellers.
        Dirty cheap imo. Part number is RC3022k.
        yotka
        Post by yotka »
        Ben, this seems to be wrong.
        Just got my 95 GPX tip's tranmission oil replaced along with the filter.
        My mechanics ended up using the Repco SFS 448 Auto trans filter as the Z411 is the wrong filter.
        Cheers.
        Cheers.
        So another filter out there fits. Good to know.
        There's a Z411 on my misses car as we speak. Can post pic if you like.
