Error 24 - Vehicle speed sensor
wildfaye
Post by wildfaye »
Hi guys,
My mechanice had used the Mut 2 and got the above error code.
My symptoms are: once the car is started, it dies off immediately.
There is no problems with cranking, battery is new.
Temporary remedy is to restart and depress the accelator immediately to raise the revs.
This occurs once in a while, not always. No probs with daily driving, just weird starting occasionally.
We resetted the error using the Mut 2, but it has since re-occured.
Whats the best remedy?
Thanks!
Sam
Foe
Post by Foe »
New "output speed sensor" underneath the battery tray.
fto617
Post by fto617 »
i got a spare speed sensor from kempys in NZ
i ordered for 2 and i have 1 spare one
i ordered it when i had my whole gearbox and stuff rebuilt
if anyone need it its 125AU
fto617
Post by fto617 »
if anyone need it its 120AU sorry 125was in NZ !
G_A_V
Post by G_A_V »
how the hell did you get the mut 2 working on the fto, i tried it and it wouldnt work, i expected you need an fto module
fto12345
Post by fto12345 »
who has this mut2?
Maybe this might pick up why my mivec isn't working?
Any ideas?
If so do you think I might be able to have my car connected to this and test it?
Thank you,
wildfaye
Post by wildfaye »
Hi, thanks all, I'll continue to monitor the situation before setting out to buy the sensor. Any part numbers thou? i cant search 'output speed sensor' in the Caps program.
How did the Mut 2 work? err...it just plugs something under the dash...not bery sure thou...my mechanic did it for me...plug n play...
fto617
Post by fto617 »
i dont have the part number
but my part came off an fto
fto12345
Post by fto12345 »
Hey wildfaye,
where are you from?
How much did it cost for checking with the mut2?
Thanks,
wildfaye
Post by wildfaye »
I am in Singapore. My garage does it for me free.
