replacoing old waterpump in service?
fto617
Post by fto617 »
hey guys since fto is getting old itt needs to have waterpump replaced.
In UAS major service thing in the website
they said u need to pay extra 550AU + labor to replace a waterpump
does it actually cost this much????
is it a big hassle to remove the waterpump?
dannyboyau
Post by dannyboyau »
to replace the water pump you need to remove the timing belt as the timing belt runs the water pump
fto617
Post by fto617 »
ar ic !
thanks danny !
G1
Post by G1 »
is that water pump for the windshield spray?
i think mine got a bit weak recently
Disrespect is easy. Respect is the difficult road to take.
smorison
The Godfather
Post by smorison »
danny
AC has to come completely off...
engine has to be unbolted on that side ...
its a real bitch of a thing to get out...
and yeah they really cost that much :(
RT
Post by RT »
G1 wrote:is that water pump for the windshield spray?
I have concern on that too....
What is it and what is it used for?
RallyMad
Post by RallyMad »
Guys the water pump they are talking about here actually pumps water and coolant around your motor and the radiator. But come to think of it I don't know what pumps the water up to the windsheild squirters, I thought that maybe there was just a little pump in the bottle of washer fluid themselves. I wouldn't think that much pressure would be required for that. :wink:
smorison
The Godfather
Post by smorison »
RallyMad wrote: Guys the water pump they are talking about here actually pumps water and coolant around your motor and the radiator. But come to think of it I don't know what pumps the water up to the windsheild squirters, I thought that maybe there was just a little pump in the bottle of washer fluid themselves. I wouldn't think that much pressure would be required for that. :wink:
the waterpump for your washers is located on the underside of the washer bottle... if they are going they should be easy enough to replace... i doubt they are unique to the FTO...
salacious
Post by salacious »
A lot of the time it is actually the nozzles that are blocked and it isn't the pump in the bottle.
RallyMad
Post by RallyMad »
Ahh yes, the old faithful needle :lol:
jonowong
Post by jonowong »
the water squirts from mine go over the car and dont hit the window
salacious
Post by salacious »
jonowong wrote:the water squirts from mine go over the car and dont hit the window
You can also use the needle to adjust where it sprays 8)
