Any ideas on what that thing is above the throttle body? it is like a circle thing and links to the throttle butterfly, it has a sensor beneath it too that is also connected to the throttle body?
That sensor Fu*ked my car big time, when set normally at low revs my car begins bunny hopping, its going good then the car sorta stalls then is normal again over and over, i fully retarded the sensor and haven't had the issue since.
It wasnt the tps or the isc, it was on the other side of the throttle opposite to the tps. Hooked in very much the same way though.
vanadinite wrote:That sensor Fu*ked my car big time, when set normally at low revs my car begins bunny hopping, its going good then the car sorta stalls then is normal again over and over, i fully retarded the sensor and haven't had the issue since.
Never had those problems, I just need to clear my error codes as I know that's the issue.
Are u coming to Brisbane tommorow vanadinite as I have full fro manuals printed out and could have a look possibly.
I'll be in brissy for a bit. probably wont have time to stop though. Thanks anyways, maybe saturday? And i'm pretty sure that sensor of mine is farrrrkkked and thats why my tcl light flashed in the first place. Im hoping to fix that, replace the sensors and go from there.
vanadinite wrote:ideas? since i've owned the car the TCL off light flashes until i hit the TCL off button. The only errors i get are about the sensors, such as rear abs sensor open and rear abs senor ???......
Extracted from the FS thread.
Yes, I'd say you'd need to fix the ABS codes in order for the TCL to function *properly*.
Owners with TCL typically turn it off anyway as it's too intrusive.
Actually its not that bad at all. I just turn it off on mountain runs.
