Window dropping once at top
Has anyone had this problem, when I sit in the drivers seat and hold the passanger window button up it goes up fine but once it hits the top it goes back down automatically about half way so you basically have to guess when it gets to the top and let go of the switch for it to stay there. Any idea why this is ? thanks
- Shhtuart
Re: Window dropping once at top
Your switch might be dirty. It's a feature of the car though, you just need to hit the button once and it closes and opens a fraction, so you don't have your hands off the wheel for too long.
Mine was a bit sticky so I cleaned the switch and haven't had any issues since.
- vanadinite
First FTO issue I ever had. My window guide was so badly gone that it jumped off the rail and sat behind the rail basically causing it to jam when it gets to the top from all the strain which then engaged the automatic down feature your experiencing. Yours has maybe done the same. Good luck
It does that if its not adjusted properly. There is a stopper that can be adjusted but im not sure which one it is (door lining off)
- ObsidianRadio
I had this issue with the black one when I first got it. You'll need to take your door lining off, and check tat all the wheels are on the rails as one of mine had come off, and that's what was causing the problem...
