Fto cold start problem
- Danielk
Hey Guys
I recently had a issue where the car won't start unless i keep my foot on the accelerator for a few minutes to warm it up.
I have replaced the stepper motor.
But now, it won't start first go but starts second go every time.
It turns over but dies the first time and second time it starts up normal.
Any ideas?
Cheers
Any ideas?
Cheers
Re: Fto cold start problem
Have you adjusted the idler screw?
- SchumieFan
Don't do this^
What other problems does it have? Could be fuel or electric... When was the fuel filter changed last?
It's could be way down
Mine was... Everyday when I first got it I had trouble, then found out about the screw , turned it abit, and has never stalled itself since
Don't touch the idle screw.
Mayte if your car is idling at 6000rpm I promise u won't have any cold start issues... Ill send u my account details so u can fix me up..
Cheers
Cheers
If your car mivecs at idle then you have a problem.destinationtoby wrote:Mayte if your car is idling at 6000rpm I promise u won't have any cold start issues... Ill send u my account details so u can fix me up..
Cheers
- Danielk
I had the fuel filter changed 3 months ago.
It idles currently at about 600rpm.
- Danielk
Could it be the timing belt or alternator belt? Hasn't been replaced in about 80000km's
- SchumieFan
no, that wouldnt effect starting...
either a battery, starter, fuel issue or a pump or injector issue,...
what fuel have u been using? ive had similar problems with BP 98
- Danielk
I've been using 95 mostly, sometimes 98 usually from Caltex.
I get a whining noise as well when it's idle at the lights, sort of a whine then stop whine then stop etc which is constant, been doing that for a few months, seems to go away when i drive though.
- SchumieFan
to be honest, you've covered the bases with the stepper motor and fuel filter...
best guess is its electrical... either the the fuel pump or the maf sensor (if flooring it to start has anything to do with it)
- Danielk
Seems to happen only in mornings when it's a bit colder when it hasn't been turned on for 10 hours or so.
After work which is 8 hours it starts fine first go though
Still better then it was before, where it wouldn't start without flooring it.
Will try the fuel pump.
- vipfto
sounds like fuel pressure. not enough for first start but once pushed a bit through seems ok FPR maybe on way out
Have you reset the ECU since replacing the stepper motor?
Disconnect the battery for about 15 minutes and reconnect it.
- Danielk
Is the FPR easy to replace?
No i haven't done a ecu reset, i'll try that.
- vipfto
Yeah simple or van just go after market. But it may not be issue Either
- Danielk
Found a part so i'll give it a go.
Is there a guide on how to change it?
Could be AFM if GR.
