Hey guys is it possible that lengthening the hard hydraulic line for the clutch would cause problems?
The line was damaged so I replaced it with a longer piece to route differently but I think it's causing problems. Everyone tells me it shouldn't cause anything and my problem is the p/plate. I installed a new slave cylinder and new master seals but slave either sticks too far out cause slip or won't go out far enough to get clutch. I still think it's the hydraulics and not the clutch/(p/plate) assembly. Thank you.
Hydrualic lines
- vipfto
Re: Hydrualic lines
nope i made a braided line for mine, hydraulic is pressure related wont matter how long line is provide it bled correctly
