Heat settings 1 and 2 not working.
GazGPvR
Post by GazGPvR »
As it was cold this morning, I had my FTO running for a few mins before driving. I tried to put the heat on setting 1 and two but nothing happened, but when I put it on setting 3 or full - it works with no problems.
Any ideas what the problem might be?
Cheers, Gaz :)
Gaz
Re: Heat settings 1 and 2 not working.
Unsure of the manual control system, but if it's a point of contact dial, then the mostly likely cause if the contacts being oxidised.
The metal tabs simply need to be lightly sanded back to remove the layer of oxide for proper contact to be made.
Again, only if its a point of contact dial.
Happened on my old Hilux.
GazGPvR
Post by GazGPvR »
Astron_Boy wrote:Unsure of the manual control system, but if it's a point of contact dial, then the mostly likely cause if the contacts being oxidised.
Nice one, I'll check that out. Cheers for that :)
Gaz
If it ends up being something wrong with the controls themselves and it cant be fixed, I actually have a manual replacement unit on the shelf in the shed. Given the vast majority are running the climate control unit, if you do end up needing to replace it, im guessing it would be quite hard to otherwise track down.
    GazGPvR
    Post by GazGPvR »
    dstocks wrote:If it ends up being something wrong with the controls themselves and it cant be fixed, I actually have a manual replacement unit on the shelf in the shed. Given the vast majority are running the climate control unit, if you do end up needing to replace it, im guessing it would be quite hard to otherwise track down.
    Thanks Dwayne, I'll get it checked. Forgot to mention it to the mechanic as I left it in today to get timing belt and water pump done. Not a big problem but I want to have everything just right! If the controls can't be fixed, I'll give you a shout
    Gaz
    I imagine is more likely a stuck flap or something like that
      Probably just the resistor block is fucked, check on the outside of the evaporator
      Pretty sure the manual controls are the same as a couple other Mitsis.
      MADFTO
      Post by MADFTO »
      Same as a CE Lancer AFAIK.
      At least they cosmetically look the same.
      HEATER???? In Oz REALLY!!!!!
      GazGPvR
      Post by GazGPvR »
      vipfto wrote:HEATER???? In Oz REALLY!!!!!
      Ha...I don't like cold mornings :lol:
      Gaz
      Only time I use the heater is when it's below 5 degrees. :lol:
      I have permanent heating :(
      FWP lol
      Yeah, but most of you live in Sydney or just north. Never gets cold there. But listen to you winge if I hold the bonfire in may/june instead of April.......
        dstocks wrote:But listen to you winge if I hold the bonfire in may/june instead of April.......
        I loved it! :lol:
        I moved to Australia for the heat.... If it gets cold I reserve the right to whinge!
        And I reserve the right to pay out on you for it... :P
