cam gears and tensioners
Ephercius
Post by Ephercius »
ok guys so next month the fto is up for a service and i need you help im changing the timing belt but since half of the engine will be allready in the way to do timing belt i was thinking of doing that piece in full
new water pump... from camskills... since the oringinal one in malta costs 250 euros
new cam gears in billit i prefare works but i could not find
http://www.ebay.co.uk/itm/Mitsubishi-4G ... 337201df85 dont know how may i need either...
new tensioners
need help on these i want something good.... would be nice if i can find the same as the billit
new hose pipes
http://www.ebay.co.uk/itm/SAMCO-SILICON ... 460c2ae0c7
suggestions would be nice please also if anyone knows what i can change while im there please just do so and tell
thanks
Ephercius
Re: cam gears and tensioners
Post by Ephercius »
anyone ? :)
Is your FTO a 4G93?
Those cam gears are for a DOHC motor whereas yours should be SOHC.
Either way if you have no other mods then there is no need for these at all.
The tensioner, I heard that you should really only buy OEM tensioners as aftermarket ones have a high rate of failure.
Water pump, it's good to get OEM but I think there are good aftermarket ones (as well as bad of course). I don't know which are good and which are bad
Ephercius
Post by Ephercius »
at the moment no other mods yet but since im doing it i ought of finishing them off imminently..
as for my model its 2000 cc DOHC MIVEC 24 valve V6
while with regards to the timing belt i bought the nipparts one... Mitsubishi parts ask was too much for these kind of things...
I think it's the aftermarket tensioners which may cause issues not the actual timing belts.
Why would you use 4G93 cam gears in your 6A12?
Though I've heard they work, you just need to modify one of them.
I think however don't upgrade them until you need to upgrade them
All you need to do is transfer the pickup plate off the first one over to one of the new gears.
Ephercius
Post by Ephercius »
spetz wrote:.
belive me here its very hard to find someone to work on it... if only seen a max of about 5 ftos in malta....2 of which are the same owner....
so im figuring that i might as well do it now since im planning to do a turbo probably and some other staff...
