Rear wheel bearing
- dr390
Rear wheel bearing
Where can I get rear wheel bearings? Or does a front wheel fit at the back aswell?
- vipfto
Re: Rear wheel bearing
Complete unit can get off ebay, depends if abs or not. Just unbolt hub nut and swap em out.
Fronts are a bitch press fit job
- Shhtuart
I've got 2 pre facelift abs rear wheel bearing hub assemblies. $260 free poatage for both they are the ones from the ebay zacsbearings I bought the wrong ones for my facelift and these were never fitted.
