Rear camber bolt seized
Re: Rear camber bolt seized
You get the new bolts and installed yet?
Hes gonna need longer ones with that asr subframe brace.
Yes I got the new bolts off of Dwayne and everything is in except for the ASR brace.
- shadowarrior
- Tightarse
Ok... this is scaring me. I might get the bolts before I start working on them. :/
The bolts are the same as a lancer so do it not on a Sunday and you'll be fine... (So if you need to cut the bolts out you can shoot to the wreckers)shadowarrior wrote:Ok... this is scaring me. I might get the bolts before I start working on them. :/
- payaya
Looks like the cut bolt is away from the sleeve in your pic. If the bolt is still stuck to the sleeve (it's more a bearing than sleeve) how did you get the control arm back on??Vectose wrote:I didn't get the bolt out. It is still stuck in the control arm bush sleeve.
I cut it on both sides between the chassis and control arm so that the control arm just drops out.
Press out bush and press in new one.
