GPX parts
- 95Xena
GPX parts
I'm in need of a timing belt kit with seals (mivec - could only find non-mivec) and a bearing kit for my lovely grindy gearbox (amazing what you can hear when you fix the noisy exhaust!). Also a water pump.
I couldn't find any of these things on Ebay. Am I just having a sh*tty search day or do I need to get them elsewhere?
Anything with tits or tyres ... bloody expensive
TIA
TIA
- 95Xena
Re: GPX parts
Oh, looks like I found the water pump Not exactly cheap
Re: GPX parts
Water pumps are $80 from supercheap95Xena wrote:Oh, looks like I found the water pump Not exactly cheap
Bearing kit for gearbox is on cobratransmission.com
And timing belt kit is on eBay, make sure you get a mivec one if its mivec
- 95Xena
Re: GPX parts
Cobra Transmission! Thank you. I couldn't for the life of me remember where I bought the bearing kit for the GR
Supercheap it is then ... pity I didn't ask this BEFORE I went there an hour ago. Going up to see Doctor Who on Sunday and pick up the XBox One and Assassins Creed (YAY!) so I'll pop in then and see if they have any.
Couldn't find a mivec timing belt on Ebay. Only the non-mivec, same as I bought for the GR ages ago.
Re: GPX parts
- 95Xena
Re: GPX parts
Thanks bud
Ugh, it's the hundred dollar day. Everything costs at least a hundred dollars. Luckily, it's not a Sahin day ... can't afford $200 for each thing
Re: GPX parts
lawl.95Xena wrote:Luckily, it's not a Sahin day ... can't afford $200 for each thing
- 95Xena
Re: GPX parts
And the camskill link is a bust It's the seals I need, not the belt. Stupid drippy car.
I think I should not have gotten out of bed
- payaya
Re: GPX parts
Im pretty sure the GR and GPX all use the same seals.
- 95Xena
Re: GPX parts
I was wondering about that.
