Engine light on!
c0n13oX
Engine light on!
Post by c0n13oX »
My engine light came on after doing an auto fluid change and adjusting the idle as it was idling at around 1500 -2000. Now everytime I change between 1st and 2nd or 2nd and 3rd the car starts jolting really bad as well as the engine light being on.
any ideas?
Re: Engine light on!
c0n13oX wrote:My engine light came on after doing an auto fluid change and adjusting the idle as it was idling at around 1500 -2000. Now everytime I change between 1st and 2nd or 2nd and 3rd the car starts jolting really bad as well as the engine light being on.
any ideas?
what fluid did you use? And did you put enough in?
c0n13oX
Post by c0n13oX »
Dex III - Castrol.
Im pretty sure we did use enough.
c0n13oX
Post by c0n13oX »
could using too much cause this? or would have to do with the idle?
c0n13oX
Post by c0n13oX »
If it helps, it also drops from 400 to 600 RPM when i dont have my foot on the pedal at all.
Chebus
Post by Chebus »
c0n13oX wrote:If it helps, it also drops from 400 to 600 RPM when i dont have my foot on the pedal at all.
:scratch: did someone fail maths?
c0n13oX
Post by c0n13oX »
about* not from :P
Chebus
Post by Chebus »
was gonna say, thats a pretty low idle :P
Also i have no idea how to fix, im still a noob.
c0n13oX
Post by c0n13oX »
Fixed! just had to clean out the throttle body and adjust the sensor. :D running better than before :D
95Xena
Post by 95Xena »
Purely out of interest, what does your idle sit at now?
One day I'll be the cat that curiosity kills :roll:
c0n13oX
Post by c0n13oX »
i think its sits around 1000 now. too wet outside to go and check :/
Thats about where it should sit (maybe slightly lower).Anywhere from 700 to 1000 is good. WMay sit slightly higher (1500) until warmed up.
    Yep mine idles around 700.
    c0n13oX
    Post by c0n13oX »
    Okay so maybe not fixed. started stalling again when i started her up earlier :( but i think the revs were lower than 700. will adjust them tomorrow and see how that goes
    Stepper...
      c0n13oX
      Post by c0n13oX »
      Easy fix or?
      Stepper causes the engine to stall if it is stuffed. You can get new ones off Ebay for around $170 from memory. See if you can borrow a club members to ensure that is the issue first, but its a fair chance.
        c0n13oX
        Post by c0n13oX »
        Whereabouts in the engine bay is the stepper motor located? (Noob question probably)
        Right under the throttle body
          Or let it learn to idle again lol
