Relocating Indicators to original holes
- Corey95
Is there any other way to relocate the front indicators to their original position (facelift) the mounting brackets that have been put in don't line up with the original holes
Re: Relocating Indicators to original holes
No, because when they complied the car, they threw away the proper brackets and put in ADR complied ones made to fit the foglight holes. You need a set of the original brackets to fix this problem.
- Corey95
You wouldn't happen to have a set would you Dwayne?
Actually, I might. Ill have to check the white facelift bar. I think it has a set of indicators bolted into it.
- Corey95
