Quick fix for wheel scrubbing
Corey95
Post by Corey95 »
I just bought evo 8 17" enkei wheels today, took it for a quick run to only find they're scrubbing the guards :( any way to fix this without having to spend too much money :(
Re: Quick fix for wheel scrubbing
Corey95 wrote:I just bought evo 8 17" enkei wheels today, took it for a quick run to only find they're scrubbing the guards :( any way to fix this without having to spend too much money :(
thats exactly the same wheels I run with no problems at all... Take the guard liners out
Could be a different offset though couldnt they?
Where exactly are they scrubbing? On full lock or continuously or going over bumps?
    Corey95
    Post by Corey95 »
    So far going over bumps that causes the scrubbing, could adjusting the coil overs also help give clearance and camber / wheel tuck
    Just hardened the coil overs now : / haha
    Yep, that would probably help.If you arent prepared to do that, youll have to lose the guard liners like Sahin says
      Corey95
      Post by Corey95 »
      Update
      -Stockies are back on 2 are down to the bulbs....
      -Removed front guard liners
      -Coils hardened (somehow feels better than softened coils 8O )
      -Need to remove rear liners still.
      -Wheel offset still seems wide on the back and front and can't roll front guards unless I go back to oem :(, not sure if spacers were run or what kind if they were, do your tyres line up slightly wider than the guards sahin?
      What tires profile are you running? Mine seriously do not scrub at all anywhere
      Corey95
      Post by Corey95 »
      235/45 , found problem number 1, hubcentric spacers...
      That would be your problem right there. Tyres.
      235/45 and a lowered car would cause the scrubbing.
      Yeah I run 215/45
      Corey95
      Post by Corey95 »
      Will removing the spacers give more clearance to the guards, since i can't really roll the front being fiberglass
      zuihoujueding wrote:Hi guys. My ride is maybe up for sale. Thinking of upfrading to an S2000 / 350Z.
      http://www.carsales.com.au/private/deta ... rt=default
      [EXTERIOR]
      25mm billet hubcentric spacers
      Corey95
      Post by Corey95 »
      plus removing the rear liners, should give enough clearance until I can slowly get the money to change the tyre widths :lol:
      Rear liners? Wut
      And with the front guards being fibreglass you can just cut them you don't have to roll them but I haven't had to do that...
      Corey95
      Post by Corey95 »
      Oops :lol: guard liners ;)
      The rear does not have removable guard liners! Its part of the chassis and is metal
        Haha yeah that would defs scrub everywhere on 235/45 with those enkeis. I can only get away with it as I'm running +20 offset. The spacers will be helping your cause, see if u can get bigger ones!
        Also get a wheel alignment and raise it up a bit :)
