KNOCKING CLUNKING SOUND
Kashikhan55
Post by Kashikhan55 »
okay so have had this problem since a month now and its driving me crazy.
every time i turn and or go over bumps i hear knocking clunking type of sound at the front usually
what could it be? swaybar? shocks? anyone else had this problem?
Re: KNOCKING CLUNKING SOUND
Either the swaybar links or cv joints
Sway bar bushes
That ^
Kashikhan55
Kashikhan55
approx how much does it cost to repair these?
DIY or having a mechanic do it?
CV joints are like $50 for the kit from memory from fleabay.
http://www.ebay.com.au/itm/Mitsubishi-F ... 0b7&_uhb=1
Edit: 40 bucks! (each)
You need to have a look and play with your bits first to work out what the problem is.
Then buy the parts required.
Kashikhan55
fair enough..
having a mechanic no time for doing it myself
thanks phil n daniel
Fair enough. In that case I would suggest finding the problem first then saucing your parts then taking them with the car to your mechanic. Otherwise they will charge a bit more for parts.
Kashikhan55
sounds good
going to narrow the problem down this week
thanks
Daniel2019 wrote:Fair enough. In that case I would suggest finding the problem first then saucing your parts then taking them with the car to your mechanic. Otherwise they will charge a bit more for parts.
my mechanic gets my parts cheaper than I can ever find them... He's a family friend though
And I've only taken my car there once
PHIL069 wrote:You need to have a look and play with your bits first to work out what the problem is.
I play with my bits all the time but that doesn't seem to solve any of my problems :lol:
I bet it solves all your problems for a short time ;)
