Mivec Cylinder Head Removal
- Nacho
Rebuilt a GR engine in the past and cylinder head was piss easy to remove. Cracked open a Mivec head and there's a bit more clutter blocking the cylinder head bolts. The work I gotta do is on the bottom end so would prefer not to dismantle the top end. Eg. cams, valves, etc.
Anyone removed head before without taking it apart? Any tips or tricks to it?
Re: Mivec Cylinder Head Removal
You need to remove the cams. Then you will be able to access the head bolts.
- SchumieFan
Yep cams out.
Yeah gotta get the cams out mate
Yeah cams have to come out
Pull the cams out
Rip out those cams
Cams removal prior to head removal mate
Cams have to be removed prior to the head
Head cannot be removed before cams mate
wut
Shut up Shane-o
I wonder if he got the point?
- Nacho
Turns out the whole top section comes off so I don't have to take everything apart. I should have been more specific.
And now I can get to the head bolts so the wizard can rip apart the block and replace the piston rings you fried.
Hypothetically if the head pops off while it's still inside, does the shaft stay hard and rigid?
FFS MAN HAVE YOU EVEN SEEN THE MOVIE OMGNacho wrote:Turns out the whole top section comes off so I don't have to take everything apart. I should have been more specific.
And now I can get to the head bolts so the mad scientist can rip apart the block and replace the piston rings you fried.
- Nacho
just seeing if you're awake. And he lost me at overnight parts from Japan.
