Adjusting TPS
Adjusting TPS
Anyone know how/got a guide/etc?
Read payayayaya's but its a bit confusing.
Re: Adjusting TPS
It's in the workshop manual.
Re: Adjusting TPS
Yeah I'm looking at it now but its just confusing for my small brain.
I'm just going to replace my throttle body, I have a spare.
Re: Adjusting TPS
TPS swapped and adjusted to lowest idle point.. idle screw also adjusted as low as possible.
Still idling at 2,000rpm, do I need to reset the ECU?
Re: Adjusting TPS
Vac leak?
Or intake manifold leak?
Re: Adjusting TPS
Highly doubt it, only having troubles when engine is hot. Fine when cold, fine when warm.
- payaya
Re: Adjusting TPS
Loosen tps attach pin 1 & 3 (idle switch) to an ohm meter. Slowly turn tps anti clockwise until there's not continuity and tighten.
Re: Adjusting TPS
I was woken this morning by what sounded like a giant rice bubble exploding.payaya wrote:Loosen tps attach pin 1 & 3 (idle switch) to an ohm meter. Slowly turn tps anti clockwise until there's not continuity and tighten.
I now know it was the sound of Daniels brain after he read your post Payaya.
Re: Adjusting TPS
Jokes on you...
I have a fucked coilpack/lead, not TPS
Oh.. wait..
Oh.. wait..
