Help!
- FTO-Love-Affair
Help!
So today I put more oil in the FTO and topped up with a 500ml bottle of the stuff that stops the engine from using too much oil, as it loves oil. Almost straight after I washed the car and decreased the engine. I noticed driving back to home the car had a bit of what seemed like a misfire and hardly any power. When I pulled up my grandmother noticed what looked like smoke coming from the engine, but I think it was more steam from cleaning the car burning off the exhaust, and toward the end of the trip it stopped misfiring. Have I fucked something?
Re: Help!
Your engine shouldn't be really "using oil" at any significantly noticeable or inconvenient rate..
Is it leaking out of anywhere or just burning heaps of oil?
- FTO-Love-Affair
Re: Help!
It burns a fair amount, and I know there are leaks, my mechanic knows about it, the last lot of oil I put in it was a 20-50 in the hope the oil would last longer, and it did. I understand the previous owners treated it harshly and I've had a lot of things repaired and replaced. It runs better now then when I bought it. I'll take it for a bit of a drive tonight and see what happens, hopefully it was temporary...
Re: Help!
Personally I wouldn't be using a thicker oil to mask leaks.
Your oil is recommended at a 10w40 for a reason.
Find your leaks, fix them, and move on from there.
Re: Help!
It's just left over degreaser and sh*t evaporating from ya engine bay
Re: Help!
Yeah happens when you don't wash degreaser off properly or dry your engine bay completely before driving.destinationtoby wrote:It's just left over degreaser and sh*t evaporating from ya engine bay
I'd be more worried about the misfiring and stuff, and I would also switch back to a standard 10w40 oil and fix your leaks.
Re: Help!
[quote="FTO-Love-Affair"]I noticed driving back to home the car had a bit of what seemed like a misfire and hardly any power.quote]
You got a heap of water in your spark plug holes causing the spark to short to the engine block. I have done it before.
Should have not sprayed the top of the rocker cover with a hose.
Should have taken out you leads/coils and cleaned out the water.
Anyway...Sounds like the water evaporated giving you back your power.
