Idle problems
Idle problems
Yes I know its been covered..
Basically my idle will sometimes stay up at 2,000rpm, sometimes more.
Usually it's fine but this morning started up at 2,500 from cold.
Not an idle screw issue obviously.. car is fine when in gear. Not so good with clutch in or in neutral.
I'm thinking vac leak of some description. Have a new stepper coming.. any other suggestions?
Re: Idle problems
Shoulda bought Bobby ...
Lol, sorry man couldn't resist...
But as the tree said to the lumberjack .. I'm stumped..
Re: Idle problems
Mine occasionally idles first near the 2,000rpm at cold, and goes down when in gear, but mine has never gone higher?
I'll help an eye of your thread just in case something is starting to go in mine :?
Re: Idle problems
Should jump to about 2k on first startup then gradually drop to about 800 when its warm.
Re: Idle problems
Mine did the same when I didn't put the tps(I think it's called) hose back on properly
Re: Idle problems
Hmm.
I also have a fluctuating idle. Its almost like its misfiring but it isnt as rapid. And is fine under load.
Re: Idle problems
Daniel2019 wrote:Hmm.
You should be looking for someone to blame :lol:
Re: Idle problems
Your stepper for sure.
Re: Idle problems
Wasn't stepper :lol:
Re: Idle problems
What was it then?
Re: Idle problems
Vac hose not connected properly! :D
