slight clicking
slight clicking
Hey guys have what I am pretty sure is a minor issue but just thought I might run it by you guys to see what people may think I have a sort of clicking comming from the front right of the car as I drive it doesnt just happen with turning so I dont think its cv's (although I am mechanicaly retarded) any thoughts ? Its not so much an issue as it is an annoyance hahah
- rock_it
Re: slight clicking
Hmmm... I am thinking it is either the rim, or wheel bearing.Wax anima wrote:Hey guys have what I am pretty sure is a minor issue but just thought I might run it by you guys to see what people may think I have a sort of clicking comming from the front right of the car as I drive it doesnt just happen with turning so I dont think its cv's (although I am mechanicaly retarded) any thoughts ? Its not so much an issue as it is an annoyance hahah
I didn't hear any clicking with the Enkei's, so maybe wheel?
Did you fix the horn? If not, it could be the wiring that has come loose from the clock spring..
Re: slight clicking
No horn fix yet doin all tommorow hahah will have a look tommorow and get back to ya haha I will also be putting the tein coils in the back anything tips with that? Haha
- rock_it
Re: slight clicking
Rear suspension is the hardest. We had a bit of trouble getting the old stock ones out. But got there in the end.Wax anima wrote:No horn fix yet doin all tommorow hahah will have a look tommorow and get back to ya haha I will also be putting the tein coils in the back anything tips with that? Haha
Just make sure you disconnect the battery for a while before playing with that wheel. And that you have the tool to get the bolts off. And don't force them.. You will take the head off the bolts...
Re: slight clicking
Check for a rock stuck in the tyre. One that doesn't look like Craig
- rock_it
Re: slight clicking
ROR!Bennoz wrote:Check for a rock stuck in the tyre. One that doesn't look like Craig
Re: slight clicking
Hahaha already looked for a rock and its not consistent enough to be something like that
