How to get a driveshaft nut out which is cross threaded
- shadowarrior
- Tightarse
As topic. Nut keeps spinning there... tried hammering a flathead behind it so that i can put some pressure to snap it back on a groove but no go.
Any tips?
Any tips?
- shadowarrior
- Tightarse
Re: How to get a driveshaft nut out which is threaded
Am pissed off atm, if you don't have anything constructive to add you can f**k off.silverGPX wrote:Lol
Re: How to get a driveshaft nut out which is cross threaded
Angle grinder & possibly a new CV, tightwad.
- shadowarrior
- Tightarse
All coz of the cheap ass CV nut...I kept thinking I should have used the old nut!
Can you get a nut splitter for size 32? Am searching around ebay atm.
Could cold chisel it if you had a big enough chisel.
- shadowarrior
- Tightarse
I can buy one. What size do I need?Bennoz wrote:Could cold chisel it if you had a big enough chisel.
http://www.bunnings.com.au/search/produ ... ctFrom=Any
Trying not to damage the cv's thread
tbh probably better to buy a new $39 cv aye instead of f**king around
^Sahin wrote:tbh probably better to buy a new $39 cv aye instead of f**king around
- shadowarrior
- Tightarse
Ordered another cv. Now to get the nut out.
Angle grind it off and use the old one
- payaya
Rotary hammer drill. I use mine when I get frustrated never fails haha. Definitely get through the nut on the hammer setting.
Drilled down between the castelations with a 1/8 bit parallel with shaft. Split with chisel. Really soft nut, really surprised it didn't split with just a chisel. Over torque I recon :s
Nicely done Bob!
- shadowarrior
- Tightarse
Thanks for the help Bob
Now the CV joint is stuck to the shaft...it won't pop out..have already broken a hammer, gone through all sizes of hammer, including a sledge. I can feel the CV moving on the snap ring and see the start of the splines, but it won't budge beyond that. Won't come out, won't go in anymore either.
Bob and I tried hammering it out yesterday, no go. Off to a CV shop today I guess.
Angle grinder with thin cutting disc.
- shadowarrior
- Tightarse
Thanks
We were contemplating doing that yesterday.
i think we can officially say that we
"HAMMERED THE BEJEZUS OUT OF IT"
- shadowarrior
- Tightarse
lol
I even gave it few whacks after I got back home. No go
It's with the CV shop now. The guy sighed and I could see a sense of relief on his face when I said "Don't worry, I won't be using that CV, just get me that shaft out"
