Rear cylinders misfiring
- Jase726
Any ideas what could cause 2 of the rear cylinders to misfire. Not sure which 2. I only know that it's the rear bank. It's currently sitting at the mechanics.
Thanks in advance.
Thanks in advance.
Re: Rear cylinders misfiring
Spark plugs
Leads
Coil packs
Yep all of the above. Also double check all your coils and leads are in the right cylinders.
Injectors
Did you do any work on the car before the misfire started?
- Jase726
It was the leads. Top Gun. Not even 2 years old. Thanks for the replies.
- kiz
- SA Coordinator
I remember when my last lot of leads caused misfiring. The only part of the lead that was still causing spark was white powder remnants of the wire coils . Pretty certain they were Top Gun leads also. But then I switched out for Magnecor
1998 Mitsubishi FTO GPVR AERO
Pretty sure mine are still the standard ones from factory
