Is anyone good enough to work this out?
phillbreeze
Post by phillbreeze »
Hi,
I have a Galant with a 6A12 2lt. 6 cylinder engine.
It cranks but wont start.
It has only got spark to two cylinders (from the same coil pack)
I have tested the coil packs, leads and plugs. They're fine.
I have replaced the crank angle sensor.
I have replace the coolant temp sensor.
I have disconnected and removed the after market alarm.
It still cranks but still wont start.
Has anyone got any ideas of what to do next??
Re: Is anyone good enough to work this out?
Try to get codes
But I say...
IFS...Ignition Failure Sensor
mark12
Post by mark12 »
my fto did a very similar thing, cranked but wouldnt start and it was the ifs, like phil suggested. so I recommend that too
phillbreeze
Thanks Phill and Mark. I'll try that.....
phillbreeze
..Is there a way to test the IFS?
You haven't just fitted this engine have you?
I'm looking for a IFS test procedure at the moment.
phillbreeze
No, I havent just fitted the engine.. Thanks for taking the time :D
Here is some info.
If you can read wiring diagrams you should be able to work out if the IFS is getting the correct signals from the harness.
IFS 01.jpg (63.37 KiB) Viewed 315 times
IFS 02.jpg (58.22 KiB) Viewed 315 times
IFS 03.jpg (184.79 KiB) Viewed 315 times
phillbreeze
Thanks mate.
