Low on oil
JacksonChater
Low on oil
Post by JacksonChater »
So yes the fto needs an oil fill up but i'm not sure where you put the oil in and if you can just fill it up. Does the filter and all that jazz need changing or can it be straight filled.
I know there is a big engine oil cap there but I don't know if that's the oil reservoir or something else and i don't want to be putting oil in places i'm not sure of
Also which oil is best to use?
It's not being driven at the moment bc the oil is very low so i'm stuck driving a swift around for the moment. A swift answer i need pleeeeaaase :P
Re: Low on oil
:lawso:
Strkszone
Re: Low on oil
Post by Strkszone »
So yeah I ran into a similar dilemma earlier. The oil goes straight into the engine and it'll settle at the bottom of the sump. Ideally you'll want to do a full oil change and swapping the filter out (don't mix two types of oil). I'm running 10W - 40 in mine at the moment, but the owner's manual mentions 10W - 30 for the GPX. Your best bet is to get a mechanic to change everything for you, and get all the information you can on the products he uses, so you can change it all yourself in future.
Edit: Daniel says to use 10W - 40, I'd trust his judgement over mine. I'm running 10W - 40 and it's running beautifully so yeah.
Re: Low on oil
Negative...
10w40 recommended. Shell Helix HX7 or equivalent.
Re: Low on oil
Didn't you already ask this question in another thread?
Go read those answers :arrow:
JacksonChater
Re: Low on oil
Aha no i don't believe i've asked this question before
Re: Low on oil
Take it to a mechanic champ.
