Quick question
whwotjd
Quick question
Post by whwotjd »
Hi there, just a few quick questions
Are GR tappets adjustable? (My tappets are noisy)
If not, would an oil flush and changing to a thinner oil fix or help the tappeting problem?
Thanks.
Re: Quick question
No they aren't, need to be replaced.
And generally thicker oil will mask it. But don't do that FFS :facepalm2:
Try a different brand of oil.
Re: Quick question
No and No.
You have hydraulic tappets.
A flush might help, but unlikely.
Thinner or thicker oil is not a fix.
You need to take them out and replace or attempt to clean them by soaking them in a solvent.
whwotjd
Re: Quick question
Post by whwotjd »
What oil is recommended?
This will be my first oil change after buying the car so I don't know what oil was put in previously :?
Re: Quick question
Shell Helix HX7 or equivalent.
whwotjd
Re: Quick question
Post by whwotjd »
Ok thanks greatly :)
