Does anyone have the part number for this?
Could it be this? --> https://www.sparesbox.com.au/superpro-b ... -spf2092bk
Rear sway bar mount bushes for Auto 95 GPX
- yotka
Re: Rear sway bar mount bushes for Auto 95 GPX
That's a GR link kit bush.
This is what you want: http://www.superpro.com.au/find/superpr ... 00330/vid-
or OEM: https://www.amayama.com/en/search?q=MR197003
- yotka
Thank you Ben!
Just for your information, car has been getting squeaks(eek-eek), when going over a bump, or doing a fast turn, most noticeable when there is loading(passenger) at the rear.
Mechanic tightened up the rear suspension and the squeaks were lessened, but still present.
He thinks its those worn out bushes that needed replacement.
Yeah, could be bushes or droplinks. Or both. If you're doing one, you may as well do the other, neither are expensive.
- yotka
Just an update:
Have purchased this: http://www.superpro.com.au/show-product ... PF2004-18K
Part number: SPF2004-18K
Honestly got a little worried when the part number looks different, but its actually meant for the 18mm rear way bar of a GPX.
If no further updates come along by end next week, then it means it fitted well on my car.
- yotka
Part number is correct and fitted on my car.
Didn't resolve the sounds though, so will probably look into replacing the droplinks in future.
