Aircon ticking and leaking
Re: Aircon ticking and leaking
Does it have the tube going thru the firewall for the drain on the evaporator. Also good way to test if you've got a busted heater core is get the car up to temp put the climate control on 30degrees on the windscreen and see if it turns green. Also coolant smells like sh*t and you would know.
