New Rotors and pads, quick questions...
mezje
Post by mezje »
Just completed one side and ad some questions...
1. How important is it to clean the rotors with brake cleaner before installing?
2. Can I use throttle body/carby cleaner to clean the rotors
3. Can this be done AFTER installation i.e. just spray the disk, turn it a bit, spray again?
4. What is the torque spec for the bolts that hold the caliper to the strut?
Cheers.
Re: New Rotors and pads, quick questions...
Wipe down with something to get the protective coating off. It is important.
Yes
Yes
Tight :lol:
mezje
Post by mezje »
Daniel2019 wrote:1. How important is it to clean the rotors with brake cleaner before installing?
Yes
Yes
Tight :lol:
Thanks!
Front = 88 Nm
Rear = 49 - 59 Nm
mezje
Post by mezje »
PHIL069 wrote:4. What is the torque spec for the bolts that hold the caliper to the strut?
Front = 88 Nm
Rear = 49 - 59 Nm
I did them to 80 :D
Front = 88 Nm
Rear = 49 - 59 Nm
I did them to 80 :D
:cheers:
