Threaded Plastic and Parker Wires...
mezje
Post by mezje » Tue Mar 29, 2016 6:46 pm
So both my parkers went at the same time, the rear parking lights still work as normal though. When I replaced my bumper the idiot wired 2 of the wires through the brackets and they needed to be cut. We did this at Stuart's and I remember testing the lights after cutting and all was good however maybe my memory is a bit shakey...
Would the wires in the photo below be the parkers?
Also, I was redoing my head unit and some audio stuff today, decided to fully remove my bit and bit around the bit in preparation for the new one however one of the screws facing the underside is threaded causing me many headaches... Best way to remove it?
Re: Threaded Plastic and Parker Wires...
Post by dstocks » Tue Mar 29, 2016 8:19 pm
Way to confuse..... :lol:
    mezje
    Post by mezje » Tue Mar 29, 2016 8:41 pm
    dstocks wrote:Way to confuse..... :lol:
    Hm?
    Is there a wiring diagram for the parkers/indicators?
    Post by dstocks » Tue Mar 29, 2016 8:47 pm
    Just trolling. Im on dial up atm (out of bandwidth), so no pictures........ Guessing what you said would make more sense with those.
      mezje
      Post by mezje » Tue Mar 29, 2016 8:48 pm
      dstocks wrote:Just trolling. Im on dial up atm (out of bandwidth), so no pictures........
      Found the wiring manual anyway :D
      I think I ahve confused myself. The lower lights with the indicators, they are fog lights right? My fog light switch has been burned since owning it. The parkers are part of the main headlight?
      Post by dstocks » Tue Mar 29, 2016 9:11 pm
      Nope. On a prefacelift, you have parkers, indicators and foglights in the same unit (unless you have a GR - no foglights). Only facelift have parkers in the headlights
        mezje
        Post by mezje » Tue Mar 29, 2016 9:18 pm
        dstocks wrote:Nope. On a prefacelift, you have parkers, indicators and foglights in the same unit (unless you have a GR - no foglights). Only facelift have parkers in the headlights
        Cool, I have prefacelift, I will need to sort out the wiring...
        mezje
        Post by mezje » Wed Mar 30, 2016 10:54 am
        To confirm, it was the wires we cut :oops:
        Reconnected them up with butt connectors and loomed some of the wire so it looks better.
