Anyone know size for short PS belt for removed aircon
Rob Furniss
Post by Rob Furniss »
The one on my son Rowans car has just shat itself, he removed the aircon a while back so was running a shorter belt but I can't remember the size or find it on here.
Anyone happen to know the size or 6PK number?
And yes the easy thing would be to look at the old belt that shat itself but he just kept driving as he didn't want it to cut out so we don't have it.
Cheers,
Rob
Re: Anyone know size for short PS belt for removed aircon
6PK940.
Bennoz wrote:6PK940.
Dont listen to him its wrong!!!! to short.
Best way is remove compressor and run same OE belt around other way of tensioner
Would you like a picture of it on my car? I don't run AC.
viewtopic.php?f=22&t=15644&p=299738&hil ... 40#p299738
GTFO
Bennoz wrote:Would you like a picture of it on my car? I don't run AC.
I'd love a photo, but the one in that link is a 404 :p
F@#king Imageshack c@#ts!
I'll scratch up the original
Rob Furniss
Thanks Ben.
He doesn't have the tensioner on anymore.
Woyta
Post by Woyta »
vipfto wrote: Wed May 11, 2016 5:07 pm
Actualy he is right.
Viamoto.co.uk sells as AC remove belt 6PK938. I got that belt in ma 1995 GR.
But I am having trouble with belt falling under load. I need to find out some belt tensioner, that will fit.
Woyta wrote: Mon Apr 01, 2019 8:49 pm
I pull the tensioner off & elongated the adjustment hole upwards by about 5mm. Then I was able to get good tension on the belt.
