Page 1 of 1
Need help(engine bay coolant tubing)
Posted: Sat Jun 11, 2016 6:46 pm
by Websta14
Hey guys! So I changed my fuel filter today on my fto gpx and there is a line that is to do with the coolant that goes into the back of the passenger foot well area from the engine bay and there is a plastic piping it's connected to well yeah that plastic piping has snapped :( haha what is the easiest way to fix this problemo?:)!
Re: Need help(engine bay coolant tubing)
Posted: Sat Jun 11, 2016 6:56 pm
by Vectose
Easiest would be to just bypass the lines going into the firewall. But doing this will result in not having a heater.
To fix it you either need to pull the whole dash out, or degas your air con and remove the evaporator to get access to the heater core and replace it.
Posted: Sat Jun 11, 2016 7:16 pm
by Websta14
I don't mind having no heater at all haha just until I can get it fixed to drive to mechanics or something. So how do I bypass it etc what do I do with the tubing that goes into the fire wall? When I was running the car the coolant was coming out of the part from in the dash ..
Posted: Sat Jun 11, 2016 8:07 pm
by Daniel2019
There is a line going in to the firewall and a line coming out. Remove one of those hoses.
Now there will be only one line between the motor and the firewall. Route that hose to where the one you have removed came out of the engine.
I.e. remove the heater core from that coolant circuit so it just goes back into the engine.
Posted: Sat Jun 11, 2016 8:28 pm
by Websta14
Got yah!:) thanks lads!
Posted: Sat Jun 11, 2016 11:51 pm
by bjk
Good hustle, guys.
